connection issues
- Re: connection issues
connection issues
04-06-2009 9:19 PM
I assured the CS guy that it wasnt and the problem lay with trying to hook up to their servers but hey what do I know. SO I tried the new router in just to shut them up and still no joy. I decided to migrate to +net since they had a better package and it was a few quid cheaper (and a customer service that actually helps people rather than tell them to reset the router ever sodding time).
Basically I have done the fault checker questions to the end and now its running a connection test. Im using mobile broadband to type this but I pretty sure that wont affect my modem thats connected through ethernet.
Here is what my modem page is telling me (recently updated the firmware but still no joy).
Software Version: 1.19.02
ADSL Version: 7.2.3.0
Boot Code Version: 0.01
MAC Address: 00-1C-10-02-DB-49
System Uptime: 00:00:01:07
DSL Status
DSL Status: UP
DSL Modulation Mode: Auto
DSL Path Mode: INTERLEAVED
Downstream Rate: 4512 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 12 db
Upstream Margin: 24 db
Downstream Line Attenuation: 43
Upstream Line Attenuation: 58
Downstream Transmit Power: 19
Upstream Transmit Power: 12
LOS Errors: 0
PVC Connection
PVC Status: DOWN
Encapsulation: RFC 2364 PPPoA
Multiplexing: VC
Autodetect: Disable
VPI: 0
VCI: 38
Internet Connection
PPP Login: Down
Internet IP Address: 0.0.0.0
Internet Netmask: 0.0.0.0
Internet Gateway: 0.0.0.0
As you can see nothing really out of the ordinary( well except the internet connection issue :'(). I have an extension lead from the phone socket up to my room with a filter on the end (just so the modem is in easy reach and so I could eliminate the long ethernet cable from the list of causes). The house phone is filtered and I have disconnected the ringing wire and the other wire (no.3 if i remember correctly.) so that only 2 and 5 remain. I have also listened down the phone to see if there is and noise on the line and there doesn't appear to be any at all.
I checked samknows for the status of my home exchange and it seems there is nothing untoward on there. http://www.samknows.com/broadband/exchange/NSFRA
As an extra my broadband with O2 worked for one night (18th may) and I was able to use it no problem and even got counterstrike source (3GB game) downloaded off of steam.
I'm at my wits end I think I've tried everything I know how to do. So I'm passing it over to the masses in the hope that someone somewhere knows a fix for it.
Many thanks for your time
Sandy
04-06-2009 9:59 PM
1) Make sure that your username is entered in your Modem setup in the format username@plusdsl.net
2) Call the PlusNet customer service number and ask them to initiate your service.
PlusNet used to have an automatic derection script which recognised a new customer's attempts to connect and initiated the service after about 20 mins so you nmay find that this has already happenrd.
Welcome to PlusNet
Edit: No space between userne and @plusdsl.net
04-06-2009 10:05 PM
I'll get straight onto CS just now see if they can activate it.
Thanks again
Sandy
04-06-2009 10:28 PM
He also said to reset the modem to see if that fixes the fault.
I'm just praying that this does work. I really dont want to be going the next few days without BB considered I've paid for this month.
But from what i've seen +net are quite good at sorting these things out.
Thanks for your time again
Sandy
04-06-2009 11:21 PM
Sorry to hear you're having problems.
Just checked your account and it all looks OK to me. TBH your router settings look absolutely fine too. Having said that there's nothing in our RADIUS logs to suggest that your connection attempts have reached our servers. I've just run a line test on your circuit and there's nothing in BT's RADIUS logs either.
That to me suggests misconfiguration of your kit, a router problem or a genuine line fault. It will be interesting to see what our faults team make of it hen they pick your fault ticket up.
04-06-2009 11:55 PM
I'm suspecting that its maybe at the exchange due to the above reason and the fact that your records show no attempt by my PC to connect.
If a BT engineer had to come out to my house, would I be charged for the call out if he sees I have disconnected the ring wire from the master socket? I took advice from kitz.co.uk that this would help somewhat since the ring wire acts as an antenna picking up all sorts of crap.
I myself am a trainee comms engineer so Im used to this kind of stuff and its just aggravating to not to be able to just go fix it. Plus im an impatient sod at the best of times haha.
I hope that your faults team can shed a bit more light on the situation
Many thanks
Sandy
05-06-2009 1:10 AM
05-06-2009 11:39 AM
Like Bob, I can't see any problems with your line.
From experience with Lynksis routers, I think you actually have to forcibly tell some models to connect. Can you see if there's an option to do that?
If that doesn't help, would you mind doing a factory reset of your router and then reenter the settings as per this page?
http://www.plus.net/support/broadband/help_and_setup/general_setup_guide.shtml
05-06-2009 12:16 PM
I'll report back once I get all that done.
Thanks again for your time and effort
Sandy
05-06-2009 12:47 PM
Quote PVC Connection
PVC Status: DOWN
Multiplexing: VC
Autodetect: Disable
VPI: 0
VCI: 38
then PPP?
In the settings is there an option to enable autodetect?
05-06-2009 12:59 PM
Just to add a bit of info, I did do a factory reset last night, I just didnt know i had. I held in the reset button for 10 secs and that resets the modem back to factory defaults. I re-entered all the information like username@plusdsl.net and P/word xxxxxxxx.
There is definatly nothing else I have to input to my modems settings? How about the windows side of things?
Do I have to disable my mobile broadband dial up connection? I did think it wouldn't but I dont know anymore.
Anything else that I may have missed?
Sandy
05-06-2009 1:03 PM
As this is a public forum, I've taken the liberty of editing your post to remove your username. I hope you don't mind.
RFC 2364 is g.DMT isn't it?
05-06-2009 1:59 PM
should be set at?
As far as i'm aware, RFC2364 is Point to point over ATM and g.DMT is the modulation type, but thats as far as my knowledge goes.
Btw here is a link to my modems manual. I thought it might come in handy as a reference and to see if you could spot any setting that needs tweeked.
http://www.linksysbycisco.com/UK/en/products/AM200
Sandy
05-06-2009 2:05 PM
That modulation is absolutely fine. Let us know how you get on with the frog?
05-06-2009 2:47 PM
If it doesn't work, where do we go from here?
Sandy
