can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
- Re: can my connection go any faster JOJO PLEASE ...
- « Previous
- Next »
Re: can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
21-06-2011 10:44 PM
hubby is connected ok daughter is local only
no idea why or how to fix it any help appreciated
22-06-2011 1:41 AM
Quote from: mkc66 problem seems to be solved with drivers updated on wireless card
22-06-2011 9:53 AM
well would you believe it past the 7am marker and still connected
22-06-2011 12:12 PM
I'll keep my fingers crossed for you
23-06-2011 11:23 AM
been over a day so a new graph please
Quote from: Joanne
Quote from: mkc66 Is it ok to have my graph posted again after the router has been changed?
Yes, let me know when you've had it running over a day.
Jojo
23-06-2011 11:37 AM
23-06-2011 12:50 PM
Your connection is looking much better. No drops since you installed the new router. I suppose I could try turning interleaving off. Just bear in mind that if it starts dropping again it'll have to go back on.
Jojo
23-06-2011 1:27 PM
shall we give it a go then and i'll come back here if it starts dropping again, how much difference can i expect with it off ?
23-06-2011 1:45 PM
23-06-2011 2:43 PM
24-06-2011 4:41 PM
but today I am still disconnecting as it just happened had local only no internet, the internet and the dsl lights went out not sure if this was the case when i was using my old router but i am now no longer sure the problem is solved with a new router can we do anything else or do i have to wait and see what happens over the weekend this time
24-06-2011 5:00 PM
The frequency of drops are nothing I would be be concerned about, and if you were to raise a fault they'd just pass it back to you as no fault. The main thing is that your profile isn't dropping. If there was a problem then your profile would drop and you'd get a lower speed. I would certainly think it's not worth worrying about unless that happened. I think there's a danger that we can try to over-analyse things sometimes when the most important thing is whether your performance is affected. The best advice I could give you is not to let routerstats or behaviour drive you crazy (because it will) unless you start to see a decline in your internet experience.
Jojo
24-06-2011 5:13 PM
Thanks for all the help Jojo
- « Previous
- Next »
