booting router
- booting router
booting router
11-09-2011 2:24 PM
Re: booting router
11-09-2011 8:41 PM
On the other hand restarting using the Gateway "Pick a task…" option should tell the DLM that the restart in intentional so it won't be logged as a connection drop. So this is the better approach, but always use this facility sparingly, best performance results from leaving the router connected continuously.
If you are going to turn power off it is best to log into the Gateway and disconnect from Plusnet first.
Re: booting router
11-09-2011 11:15 PM
Re: booting router
11-09-2011 11:55 PM
For setup information on the DMT software, and other useful information go to http://www.kitz.co.uk/routers/DMTv7.htm
Derek
Re: booting router
12-09-2011 2:26 PM
Having read through the DMT options am I correct in thinking we are still unable to adjust the S/N margin on the 585v8 or has anything changed/have you tried it? It would be a useful option to have a play with!
Hi Kevanne,
Maybe I'm the odd one out, [and I really don't see why it should be this way], but I find that an on/off with the rear switch works best for me every time and I get a better connection speed than the "disconnect, restart gateway, reconnect" in the router software. However unless you have had the digital line management turned off on your line I wouldn't do it more than once every few days/or unless the router is locked up, etc or Mr BT may get annoyed and start adjusting your S/M margin or banding you, and you really don't want that belive me!
So, no, don't use the rear switch any more than necessary as in theory I believe it should not make any difference.
Regards, Bob.
Re: booting router
12-09-2011 2:38 PM
Quote from: GreenGiant Hi Stumpy,
Regards, Bob.
You are correct, the option to adjust the S/N margin is not available.
I also received this reply, from a member of the Plusnet team, to a similar question
Quote from: Alex The router must be compatible with DMT Tool. Unfortunately the Thomson 585v8 is not compatible.
Derek
Re: booting router
13-09-2011 12:49 PM
Re: booting router
13-09-2011 7:01 PM
Re: booting router
13-09-2011 8:17 PM
That sounds like the DLM might have decided to try a lower target noise margin on your connection (which will increase sync speed), but a few days later decided this caused too many transmission errors so increased it again (restoring the original sync speed). However without knowledge of the router stats this is just guesswork.
Have you a record of router stats for the relevant period? Information on how to get and post TG585v8 router stats is in my post here.
David
Re: booting router
13-09-2011 9:42 PM
