bbc i player 0x60 on 21cn trial
- Re: bbc i player 0x60 on 21cn trial
11-05-2009 8:47 PM
http://usertools.plus.net/status/archive/1242042994.htm
but I'm looking to see what else could be causing it as it might be the packet loss was within the BT side of the network in which case BT will drop any type of traffic and from any customer, whereas if we were dropping it we'd drop the low priority traffic first. I've got a case open with BT to see if the traffic was being dropped by their policer in which case it may be that the bandwidth increase hasn't been set right somewhere.
Plusnet Technology
11-05-2009 8:59 PM
11-05-2009 11:25 PM
This lime an akami being used for iplayer is completely new to me. before i just thought bbc ran there own stuff
no packet loss on icmp pings tho
12-05-2009 12:03 AM
PS no DRM; no expiry period
12-05-2009 1:09 AM
are you on the trial and what speed you getting on streaming ( one of the legit ways that is ;D)
12-05-2009 2:08 AM
Download Speed: | 3965 kbps |
Streaming Speed (1): | 4042 kbps |
Streaming Speed (2): | 4051 kbps |
Streaming Speed (3): | 3837 kbps |
12-05-2009 9:22 AM
Quote from: ASBO yes evil. i should know about your way of getting iplayer downloads as it must be the 100th time ive seen you post about it
I keep banging on about get_iplayer because it's so much better - sorry.
Yes I'm on the 21CN trial - but all I get is a measly 6Mbps download speed - I can get 6.5Mbps on ADSL MAX
How can I get a streaming test that outputs a number?
Generic or Linux please - and not one that involves installing that crock of **** called AIR
BTW the BBC streaming content is really poor quality - even their so-called HD flash is only laptop quality (seen it once, never again).
I'm looking for wide-screen 1600 x 1050 quality on Linux - and I don't believe flash can do it.
12-05-2009 10:08 AM
12-05-2009 10:23 AM
12-05-2009 5:39 PM
A bit less and it would be octal.
12-05-2009 10:27 PM
what's the update on this?
12-05-2009 10:43 PM
Quote from: Crucibleofevil This is a very geekish thread - people(?) talk to each other in hexadecimal
Are you having a nibble on this thread too?
3Mb FTTC
13-05-2009 2:12 AM
Quote from: godsell4 Are you having a nibble on this thread too?
At risk of repeating myself, use http to do a download, then play it back.
No DRM, no time-limiting, no need for flash and no need for nibbles.
Oh yes, your download runs at the full speed of your connection.
But if you absolutely must use flash, get_iplayer will download about 6 streams in parallel,
join them all up for you and save the resulting mess on your disk.
Because you're intercepting the flash output there's no DRM or time-limit
13-05-2009 7:30 AM
but this thread is trying to get iplayer traffic picked up right on 21cn. so people with less knowledge than your self can use iplayer the way its intended to be used ie without any work arounds on any DRM rights.
PN whats the story with this akamai and lime ip's being used in the evening?
streams have been un usable since the weekend
13-05-2009 10:47 AM
So for me iPlayer is "usable". -
