YouTube Video uploading
- Re: YouTube Video uploading
13-09-2013 12:21 PM
I would defo suggest asking PlusNet to stick it up as a guide for people on there FAQ stuff and yeah it cant hurt to post a blog page with that on plenty of people have problems but have no idea what it is and often will resort to a full reinstall of the pc to *fix* any issues
13-09-2013 12:24 PM
Anyway great stuff and thanks for your help and the same to all on here.
Plus Net, do you want that guide?
dick:quote
13-09-2013 12:35 PM
What exactly did you change which fixed it.
If it was MTU what was it and what is it now
13-09-2013 12:48 PM
Quote from: Oldjim For my benefit - as I got lost with all the varying suggestions
Hi, if you look a couple of posts above you can find my pdf showing what I did, hope it helps?
13-09-2013 12:50 PM
probably from the post I linked him about how to reinstall the default values then rebooted the pc, the advantages of running the built in repair tool from a command prompt is it deletes and puts in new registry keys which eliminates registry corruption as the cause (something that quicktime and other download managers often cause) if he had run the Microsoft fix-it tool that wouldn't have changed the registry values and left him in the same boat if it had actually run instead of throwing up an error......
it is possible to mess about with the whole stack disable all or part of it and even delete then build it from scratch but it doesn't often work unless you also edit the registry keys to match what your writing in the setup values (something various blogs on the net elude to but few if any come straight out and say it) the best advice in future is leave it all running in auto mode (it is by default) and if problems crop up in the future re run the reinstall process
but overall I would advise upgrading to a newer OS before XP goes into unsupported mode (that's when MS will remove all there current XP help files from there website)
13-09-2013 12:54 PM
13-09-2013 12:59 PM
Thanks - missed that
Quote from: MikesMovies Hi, if you look a couple of posts above you can find my pdf showing what I did, hope it helps?
13-09-2013 1:05 PM
failing that put your iphone on the back of your chair and just make a video that way (given that your pc is running iphone software i'm assuming you still have it) with the added bonus of being able to record the voice at the same time as the visuals
13-09-2013 1:06 PM
Feel very happy to have this matter sorted, if only I'd found you guys earlier
13-09-2013 1:16 PM
Is it really necessary to block those IP addresses, or does it still work without those blocked, after the netsh reset command?
13-09-2013 1:31 PM
and yes it is unnecessary to run the fix-it tool and then reset the stack to default (the fix-it tool is also largely pointless as most problems are a result of incorrect registry key entries which it does nothing about)
13-09-2013 5:16 PM
Quote from: nanotm before XP goes into unsupported mode (that's when MS will remove all there current XP help files from there website)
Sorry but what? Microsoft aren't going to just start pretending that XP doesn't and never did exist in April next year, they just won't release any new updates for it.
13-09-2013 6:17 PM
Quote from: nanotm yeah but unless your running something else then your on a ppp connection (I think virgin uses a different type) on a phone line based isp
I'll clarify what I said earlier: The microsoft fixit tool only changes the MTU for PPP connections created by the Windows PPP networking components, which aren't being used here. So it has no affect.
13-09-2013 8:21 PM
13-09-2013 11:36 PM
Quote from: Razer It seems, then, MikesMovies, that you did what I did (and mentioned earlier), you reset your TCP/IP stack. Makes me wonder what caused the same problem for the both of us in the first place.
Just in from work, yes I have been wondering that! I also wonder why it seemed to only affect YouTube as I was able to upload to mediafire etc without apparent issue.
Going back to my PDF, yes I will leave out the 'fixit' reference.
As to the blocked IP address ranges, This was recommended to improve YouTube watching, as it stops them throttling videos themselves! so I think on balance I'll stick with that for now
