Wrong line activated in house
Fixes: 1,641
Re: Wrong line activated in house
@Louismoodie wrote:
@Gandalf sounds like exactly that has happened.
Is there anyway to have the cable switched if it is still unused?
Or does my line need to drop below the minimum speed for any chance of an engineer visit?
I've just checked and there's no other stopped line showing in the supplier systems, apart from the line we've taken over.
As your speeds are within the supplier estimates of between 63.03mbps to 80mbps, it's highly unlikely an engineer would carry out any work (including swap to a different pair) to improve the service I'm afraid.
Louismoodie
@Gandalf Maybe should of started a new thread but it does relate to this one.
I actually had an engineer come out, and at first he found no fault, then after re-terminating some cables, and doing a 4 minute test, he found the line did start playing up.
Again, it was found that between pole and the end of street duct, there was something up.
He switched me to a spare pair of cables between the two points and things look to have become more stable.
My max attainable speed shot from just under 70mb, to now 96mb, however the line sync is still around the same.
And the interleave depth is extremely high.
Does my line need a DLM reset after the physical fix?
Fixes: 1,641
Ah glad to see that and cheers for the update.
I don't think another DLM reset will help here as it looks like the engineer did that after completing the job.
Testing your line now isn't showing any issues either. I'll attach below a copy of the testing I've run:
GEA Test Detail
Circuit ID NA Service ID [redacted BBEU]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 64.8 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 463.2
Upstream Rate Assessment Very Good
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From00:00to10:45
Interference Location Customer Premise
Interference Observed In Days 3
Technology VDSL
DP Type External
Profile Name 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2022-06-11T06:15:00
Parameters MIN MAX AVG
Down Stream Line Rate 63.3 Mbps 67.4 Mbps 64.4 Mbps
Up Stream Line Rate 19.7 Mbps 20.0 Mbps 19.9 Mbps
Up Time 0.0 Sec 900.0 Sec 892.6 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2022-06-14T13:34:45.389+01:00 2022-06-14T13:49:45.389+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 28 0
Louismoodie
Thanks @Gandalf
I'll try to leave the line alone to let DLM do it's thing.
I'm currently using an Asus router with built in vdsl modem, which uses the dreaded Mediatek chipset.
Hoping to get a HG612 tonight and then I can leave it to do it's thing.
Hoping interleave disappears and fastpath returns in time Smiley
Thanks again.
Fixes: 1,641
Good plan!
Let me know how it goes.  Smiley
