WiFi range
jenfadee77
WiFi range
Hi - just set up my Plusnet two hub. Speeds are great. However the range is nothing compared to my EE Hub. I can’t get a WiFi signal upstairs which is a huge problem as that’s where my office is! Any suggestions greatly appreciated
2 REPLIES 2
Fixes: 105
Re: WiFi range
@jenfadee77
Which product are your on SOGEA (FTTC) or Full Fibre?
Is there any possibility of running ethernet cable - even externally?
If EE haven't asked for their router back you may be able to use that if it's not locked (others will advise).
Fixes: 1,492
Re: WiFi range
Moderators Note
This topic has been moved from Broadband to My Router
