WiFi dropping constanting dropping
Cat3
The WiFi signal is constantly dropping again with the router flashing amber for several minutes at a time. I say again as this happened before and an engineer found a fault on the line and it was fixed . Incredibly annoying that the same seems to be happening again? Have tried all the other troubleshooting advice.
6 REPLIES 6
Fixes: 391
Re: WiFi dropping constanting dropping
@Cat3
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Fixes: 251
A flashing amber light is not a WiFi dropping out - it is a loss of sync - an entirely different problem.
Flashing amber light means that the router cannot sync with the exchange (if ADSL) or with the cabinet (if FTTC).
An engineer might indeed have been out to fix one fault which causes this symptom, but that can be no assurance that there are not other faults giving rise to the same symptom.  Your circuit probably has a dozen or so joints in it - anyone being a bit iffy could give rise to this symptom.
Cat3
Thank you. Will do as you've suggested.
adamwalker
Fixes: 223
Hi @Cat3, I've just had a look over your account and can see an engineer has been out to see you today. How have things been since then?
 Adam Walker
Cat3
Engineer booked for tomorrow. Thank you
willcutforth
Fixes: 113
Hey there @Cat3 has the engineer been out today?
 Will Cutforth
