WiFi Issues with BT Router
mapidd
Hi, I've been using BT Hub for a while. I have a recent issue in that WiFi drops out and I lose Internet access. Router glows orange. Phoning PlusNet their automated system tells me my line ok. Obviously power reset cures but issue returns. Can be in hours, a day or even 2. It's getting a bit of a problem working from home. Anyone had anything similar or any ideas? Thanks in anticipation.
10 REPLIES 10
Fixes: 387
Re: WiFi Issues with BT Router
@mapidd - Thanks.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
I am not sure of the layout/data available from the BT HUB , but the information we need off there is:Downstream/upstream speeds (current and achievable), DSL uptime and noise margin figures (at a minimum)
Fixes: 480
If you have contacted Plusnet whilst you have an orange light and they say that you are connected, and a power cycle reconnects you, then my assumption is that the Smarthub is going faulty. They are getting a bit long in the tooth now..
Fixes: 387
@Baldrick1 Good point re the HH6, which I hadn't considered. Still be good, IMO, if the OP could provide the information requested, just in case there was anything going off elsewhere.
Fixes: 480
@jab1
Not disagreeing at all, you will also note the provisos in my response.
mapidd
Thanks for the replies.
Came in tonight and found issue had returned. I had done a factory reset on Friday and reinstated broadband username and disjoin of 5GHz & 2.4GHz WiFi with own custom names.
As my wife is also disabled we've moved to smart home ish for lights, radio and the like
So that's becoming a pain when wifi goes down at 3am.
Love to attach screenshots made on phone, except can't see options to do this on this browser from this android phone. Although I am told of file attachment limits. Which is nice.
Downstream speed: 59.99 vdsl 2.24 adsl
Upstream speed: 20 vdsl 0.74 adsl
Noise margin from bt hub: 6.4dB / 6.5dB
Hope this helps,
Fixes: 480
@mapidd
If the hub is losing the Plusnet credentials settings regularly then that makes me more suspicious that this is the hub failing.
Do you have another hub that you can try? Depending on when you renewed your contract you might get Plusnet to supply a Hub 2 for the P&P charge. Why not ring the Customer Options Team on 0800 013 2632 tomorrow and ask?
@mapidd
"Love to attach screenshots made on phone, except can't see options to do this on this browser from this android phone"
You need to set the browser you are using to "Desktop site"
First you need to be viewing the website, then touch the three dots on the browser screen,  "Desktop site" should be somewhere on the list
HTH
James30
Fixes: 32
@mapidd - Thanks for taking my call today. I'll ring you again tomorrow to give you time to connect the newer Plusnet router and just an FYI, you can see the ticket I left here @  https://www.plus.net/wizard/?p=view_question&id=236214471 Cheers
James - Plusnet Sheffield
James30
Fixes: 32
Hiya, I gave you a ring to see if you managed to remove all the extra networking tech from the equation and test it out yet?
James30
Fixes: 32
Cheers for taking my call and confirming that it's working now with the new router. Let me know if you have any more troubles. TA
