Why so many disconnects today PN?
- Re: Why so many disconnects today PN?
29-09-2011 3:23 PM
Same symptoms as I had about a month ago. It was fine (more or less) for a month, but for some reason unknown to me I've been disconnected so many times today that it's getting really annoying.
Anyone from Plusnet able to understand why I'm being disconnected so frequently today in particular?
Message 1 of 5
(902 Views)
4 REPLIES 4
29-09-2011 3:34 PM
We can't really pinpoint why you might be experiencing disconnections on a particular given day I'm afraid. If the problem does persist I'd advise raising a fault though: https://portal.plus.net/apps/kbdfaults
Message 2 of 5
(529 Views)
29-09-2011 3:43 PM
you can see from your end how many disconnects I'm having today though. Has PN made any changes that are booting me offline continuously today?
Message 3 of 5
(529 Views)
29-09-2011 4:02 PM
I can, yes. You had a 15 day connection before today so I'm going to suggest that if this problem continues into tomorrow that you raise a fault here as the next step: https://portal.plus.net/apps/kbdfaults
Message 4 of 5
(529 Views)
29-09-2011 4:32 PM
ah okay thanks That gives me an idea of how stable my line was until today.
Message 5 of 5
(529 Views)
