Why is Eth4 highlighted in red?
ankado
Hi
My 2704n router has four yellow Eth sockets on the back.
Eth4 is highlighted in red.
Why?
I can't find any reference to it anywhere.
3 REPLIES 3
Browni
Aspiring Hero
Fixes: 60
Re: Why is Eth4 highlighted in red?
It indicates the WAN socket to be used in an FTTP install.
Fixes: 419
@ankado
When used on ADSL it means nothing and works in exactly the same way as the others. However the hub can be configured to work as a simple router rather than a combined ADSL modem/router. It can then be used with a fibre modem or on a FTTP connection.
If it is configured as a straight modem then as @Browni  says you lose the use of this socket as a LAN output but instead it becomes the WAN input from the outside world, bypassing the modem section.
The configuration can be changed in the expert_user settings.
ankado
thanks very much folks! 👍
