Why can't Google find my Website Address
- Re: Why can't Google find my Website Address
17-06-2008 7:14 PM
Quote from: katiesteddies RE: MickKi
Got www.holistictherapyforyou.com to point to www.katiesteddies.plus.com By going onto the site I registered the domain with and there they have the options for webforwarding and email forwarding. where you just type the web address or Email Address of where you would like the domain name or Email to Go. (Very Easy But don't yet Know if google likes it.)
Google has probably blacklisted you for duplicate content.
Quote from: katiesteddies What is a Robots.txt file?????????
Hmm, you haven't read the links I provided above?
17-06-2008 8:07 PM
Quote from: MickKi Google has probably blacklisted you for duplicate content.
Doubt it, the .com address doesn't contain any content whatsoever - it's blank other than the FRAMESET pointing at katiesteddies.plus.com
18-06-2008 6:44 AM
20-06-2008 2:45 PM
Or any other ideas
At least I am getting somewhere
Thank you.
20-06-2008 2:49 PM
Quote from: katiesteddies Now have google finding www.katiesteddies.plus.com but not www.holistictherapyforyou.com would the robot.txt fix this ?
Or any other ideas
Thank you.
Because of the way your host has "hosted" the .com domain as far as Google is concerned there is NO content on that site - not a single word. If you want Google to find it then you need to get the hosting out properly. I believe one of the PN reps said that this could be hosted by them for free - so I'd investigate that.
20-06-2008 8:39 PM
Instead of URL redirection, you need to go to your domain hosting control panel and point the holistictherapyforyou.com domain to the PlusNet hosting servers IP addresses.
Do this after PlusNet have set up a new domain for you to host holistictherapyforyou.com, separate to your katiesteddies.plus.com domain name.
If you send a private message to Ian Wild he will advise you how to proceed with this.
I would also recommend that you change the content. Exact website replicas are not a good idea from a Google perspective - better if content is unique in each domain.
Hope this helps.
29-06-2008 6:31 PM
Google now seems to find www.holistictherapyfor.com
will get proper hosting for it as suggested as soon as I make it look nice, Now I have to do the same for www.aboutbuntingford.co.uk ; which I am using the space www.johnwebber1.plus .com while I test it.
May need your help soon and again
Thank you for all your help with this.
29-06-2008 8:34 PM
29-06-2008 8:35 PM
29-06-2008 8:57 PM
Also your email address is in clear and will be picked up by spam web crawlers. There are a number of methods for obscuring it. I use a combination of javascript with a picture if javascript isn't enabled
29-06-2008 9:23 PM
1) use a photo of your e-mails instead of plain script.
2) replace the @ with "at"
Copy of photo for you below
29-06-2008 9:58 PM
29-06-2008 10:04 PM
29-06-2008 10:17 PM
29-06-2008 10:29 PM
Quote from: pierre_pierre Site maps are to tell search engine whats on a lousy designed site, so that they dont have to waste time looking.
Hmm, they provide a lot more than that. They provide information about how frequently the webmaster expects pages to change. This allows the spider not too crawl too frequently / slowly in order to be as efficient as possible.
They also allow you to specify a "priority" for each of your pages, telling it how you rate the importance of each of them within your site. This can be used to tailor the results they show to favour the pages you mark as important versus ones you mark as less important.
Nothing to do with "lousy designed" sites thank you very much
