What would cause TG582n to to lose WiFi on all devices at the same time
- What would cause TG582n to to lose WiFi on all dev...
Re: What would cause TG582n to to lose WiFi on all devices at the same time
02-02-2014 11:56 AM
The microwave et all does not generally affect the WiFi by more than 10dBm in this property and has never caused a dropout of WiFi
Plus there was nothing on but the devices, TV, Lights and C/H Boiler as normal, which has collectively never caused a dropout
10dBm is a pretty massive change
02-02-2014 12:02 PM
02-02-2014 1:08 PM
Telnet command:
wireless radio protmode=rtscts
02-02-2014 9:07 PM
Would it not be wise to explore other options that can be changed easily and are known to work 1st ?
For Example:
[code=Telnet file=Wireless n tweaks (TG582n only)]
Commands Comments
wireless radio cdd=enabled enabled = reduce dead spots in the wireless coverage
disabled = default
wireless radio stbc=enabled enabled = Improve signal quality
disabled = default
http://en.wikipedia.org/wiki/Space%E2%80%93time_block_code
wireless radio frameaggregation=ampdu Improve throughput by changing type of header.
amsdu -- generaly most efficient
ampdu -- (Default) Better in environments of high error rates.
http://en.wikipedia.org/wiki/Frame_aggregation
saveall Don't forget this![/code]
[code=Telnet file=Change wireless n speed (TG582n only)]
Command Comments
wireless radio channelwidth=20 sgi=enabled Wireless Speed 144(n)
wireless radio channelwidth=20/40 sgi=disabled Wireless Speed 270(n)
wireless radio channelwidth=20/40 sgi=enabled Wireless Speed 300(n)
wireless radio channelwidth=20 sgi=disabled Wireless Speed 130(n) Default
When in 270(n) or 300(n) mode the router is not very good at switching off the extra channels when not needed or when it may cause interference to other wireless access points.
For this reason please use these modes responsibly.
[/code]
[code=Telnet file=Disable wireless n speed]
Command Comments
wireless ifconfig Show wireless settings (optional)
wireless ifconfig interop=802.11b/g Disable wireless n
[code=Telnet file=Force connection modulation mode to ADSL1, ADSL2 or ADSL2+ (also disable Annex M)]
A useful byproduct of this command is that it causes a resync.
ie resetting the modulation to default (ie no change) can be used to force the router to perform a resync.
Command Comments
xdsl debug multimode Show all enabled modes. (optional)
xdsl debug multimode config=t1.413issue2+g992.1_annex_a This forces ADSL1 (ie g992.1 Annex A)
xdsl debug multimode config=t1.413issue2+g992.3_annex_a This forces ADSL2 (ie g992.3 Annex A)
xdsl debug multimode config=t1.413issue2+g992.5_annex_a This forces ADSL2+ (ie g992.5 Annex A)
xdsl debug multimode config=t1.413issue2+g992.1_annex_a+g992.3_annex_a+g992.3_annex_l+g992.5_annex_a Disable Annex M on all connection modes
92.3_annex_m+g992.5_annex_a+g992.5_annex_m Default, all modes available.
saveall Use one of the above commands then saveall !
[/code]
02-02-2014 9:40 PM
Quote from: TORPC
Cyclic Delay Diversity : enabled
Space Time Block Coding : enabled
I saw you already had seen those commands. The user.ini editing was a suggestion to workaround the pwr config usb-controller telnet command being disabled in the non-usb firmware, which I expect is a non-issue, and that command wouldn't disable the usb controller, it would disable the power management for the usb controller. But disabling the power management options is a suggestion on npr's website for fixing "intermittent network and internet access problems". Power saving for the wireless can be disabled via the web interface.
02-02-2014 9:51 PM
02-02-2014 11:43 PM
Quote from: ejs
I was not dismissing the workaround changes to the user.ini, however as it has not been proved / disproved to work atm.
I was thinking your workaround as a last resort,
since other options are available to which I was asking if they would be a viable choice to try 1st & which would be the best to try as a result of finding out what is the cause of these issue(s) so that the information can be fed back to the dev team to apply a fix or remove offending code etc
I have now unchecked (Power Reduction Enabled:) in the GUI and will see how that goes for a while
That is the only setting I am changing for now as I want to test 1 at a time
Even though npr says
Quote Note:
There are reports that having these power settings enabled can cause intermittent network and internet access problems.
Disabling all of these settings followed by a router reboot cured the problem.
Awaiting more information on this issue.
03-02-2014 11:23 AM
There's no harm in experimenting though.
Disabling the wireless power reduction has always been though of as worth while, although I thought it was now disabled by default in recent firmware.
At the risk of being accused of only skimming this thread.
I would first look at trying different wireless channels. As others have pointed out InSSider does not show interference from other sources.
03-02-2014 2:09 PM
1. Overlapping Channel(s)
2. Co-Channel(s)
Not the best examples of the congestion as it it the quietest I have seen it in a long time
screen capture windows
Using an Example of a domestic appliance that has been mentioned in this thread
It does not show Microwaves etc causing interference
However I also use WiFi Anylizer for android that confirm interference but does not tell you what item is the cause
It does however tell you what is the best channel(s) to use
I had been down the road of changing channels with my previous ISP which was described at length on their forums and on the phone support
Quote from: npr At the risk of being accused of only skimming this thread.
As previously mentioned in post #7
Quote from: TORPC I have been using channel 13 since approx day 3 - 4 of having the 1st TG582n and no issues on WiFi until last night.
<snip>
If I was to revert back to the default auto channel 11 it will become pretty useless as channels 11 & 6 are the most congested and always causes issues the other channels that are not quite as bad & still congested are 1, 2, 3, 4, 5, 7, 8, 9, 10, & 12 which was confirmed with both inSIDDer 3 an WiFi Analyzer & also clearly shows that channel 13 is the best for my area
For Reference
By default or automatic means
ISP's like Virgin Media, TalkTalk, Plusnet , O2 etc use channels 6, 9, & 11 in my immediate & surrounding areas
Therefore I am still surprised that the most popular congested channels are requested to test with
05-02-2014 7:32 PM
However it is clear that the TG582n wireless side needs a major overhaul
Will PlusNet feed all the information on these boards back to the development team ?
http://community.plus.net/forum/index.php/topic,110884.0.html
http://community.plus.net/forum/index.php/topic,108698.0.html
Most recent
http://community.plus.net/forum/index.php/topic,123410.0.html
05-02-2014 8:48 PM
06-02-2014 5:52 PM
We will wait & see how long it takes for them to address these well known issues
This is the response I have had so far
Quote from: Chris I read through the thread last night - totally forgot, apologies for that, I concentrated on the issues regarding the incorrect amount being taken.
It's the Products Team who deal with the hardware that we supply. I'll pass them the thread over so they can take a look.
06-02-2014 6:22 PM
I have my new billion router now bug happy to try any testing, or send tge router to plusnet for analysis.
07-02-2014 2:42 PM
The router supplied meets the basic requirements of the majority of users and allows PN to keep prices down. Supplying a better router would obviously mean PN had to recoup the increased costt somehow and risks making them uncompetitive.
What do you think they should do - supply the same sort of router as the premium suppliers like Andrews & Arnold?
07-02-2014 3:36 PM
I am not saying that they should supply premium router such as your suggestion
All I am saying
Is that the router, regardless of price etc, which is sent out as fully working from either manufacturer, place you do business with IE: in this case it is obviously PlusNet that sends them out
Should be
Fit for Purpose an a daily weekly monthly basis especially when less than 3 Months old,
It after 12 months then need I say any more
For all we know since there others that have their TG582ns fully working, there could be a faulty batch that needs to be recognised.
