What's happened to the Computer & Hardware section?
- What's happened to the Computer & Hardware section...
15-06-2008 11:10 PM
Basically it was there in the list when I entered the Forum but now I cannot find it.
I have just re-instaled XP (again lol) & I now have to search for the list of messages I have sent, find one for that discussion and then access through that.
Never had this issue before. Has something changed that I have missed or is it something more obvious that I have failed to set?
Forum Moderator and Customer
Re: What's happened to the Computer & Hardware section?
15-06-2008 11:36 PM
Sorry I don't know of any way of putting it back if it wasn't apart from asking a friendly Mod to check access permissions.
16-06-2008 6:04 AM
16-06-2008 11:41 AM
16-06-2008 3:36 PM
Quote from: madjbright collapse a section in the forums by clicking on the - which is to the RHS of the section header.
That is what I meant.
16-06-2008 4:46 PM
Here is how you "find" it again...
You should have a grey bar across your page with the title "General Discussion" at the right hand side of this bar, there should be a + sign in a little box. ! if you click on this, then it will (should) open the titles for General Discussion
Hope that helps ! !..
16-06-2008 5:26 PM
Quote from: shutter Chillypenquin has told you how "hide" a particular group on the forum board.....
I can't be too helpful, I have a reputation to uphold.
16-06-2008 5:36 PM
Yep, it was hidden. I never set it that way - I don't think.
Thanks for the tips.
