WIFI Drop Out
mandjnev
WIFI Drop Out
We have been with Plusnet 4 years now but have been experiencing significant WiFi drop outs for our Apple, Samsung and Windows devices in the last few months. My wife works from home and has to reconnect at least twice a day. I see from previous comments that Plusnet routers aren't the best which is probably the reason for our problems. Any recommendations on alternatives which are more reliable?
18 REPLIES 18
Gel
Champion
Fixes: 29
Re: WIFI Drop Out
Fixes: 392
Re: WIFI Drop Out
Welcome to the forums, @mandjnev So all your equipment is suffering from these 'WiFi dropouts'? What form do they take? the PN supplied Hubs are perfectly adequate for normal home internet use, and reasonable business use. It is more likely that these issues are connected to wider issues.
As a start, can you provide the information requested below?
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
Fixes: 392
Re: WIFI Drop Out
@Gel wrote:
An OpenReach one from E Bay can be configured for PN settings.
Openreach do not supply modem/routers.
mandjnev
Re: WIFI Drop Out
Thanks for your message. Appreciated.
Essentially the connection just drops and we wait for wifi to reconnect. The fact that it is happening to different devices made me think it isn't the devices and probably the router.
The router is set up in our lounge and WiFi connection drops from a device in the room and also in neighbouring rooms. I have set up TP-Link extenders upstairs for the home office and the laptop is hardwired in. This is also dropping. I've done a ping test using the Plusnet broadband checker and we are getting the performance advised in our contract.
Your recommended tests are a new to me so I'll have to read through to understand it and then revert.
Fixes: 392
Re: WIFI Drop Out
Far enough, but the information is a starting point to establish the true picture and gives those trying to help a clearer understanding.
corringham
Seasoned Champion
Fixes: 23
Re: WIFI Drop Out
@mandjnev wrote:
... the laptop is hardwired in. This is also dropping.
This make it sound as if it is not the wifi, but the internet connection that is dropping.
Do the lights on the router change?
Fixes: 392
Re: WIFI Drop Out
My thoughts exactly, which is why I have asked for what I have.
mandjnev
Re: WIFI Drop Out
Sorry I wasn't able to get back sooner. Other issues. I've done the two tests and the screen grabs are attached. I've had to do it over the wifi as my Mac doesn't have an ethernet connection.
I've checked the Plusnet router when the device disconnected and it is still displaying blue on the device. Looking at the performance tester the speeds appear to be fine and within contract terms.
I've also done the Quiet Line test and that was clear.
The disconnects appear to happen on iPads' and the HP laptop (with MS) more often than the Mac. It's baffling me.
Really appreciate your help and advice.
Fixes: 392
Re: WIFI Drop Out
@mandjnev The rest of the information requested in my original post is needed to give a full picture, although the screenshot provided does indicate your speed is reasonable, although a little low.
mandjnev
Re: WIFI Drop Out
Thanks for the quick reply.
The other bit is where I get a little brain fog. That's the bit I'm not too sure where to go or fully understand.
Is that something I do from my Plusnet account?
Fixes: 392
Re: WIFI Drop Out
The BT Performance check is done by clicking on the link, the broadband connection status, as said, is from your Hub.
mandjnev
Re: WIFI Drop Out
I did those and attached the screen prints. Can you not see them?
Fixes: 392
Re: WIFI Drop Out
I can only see the first of them - are you sure the others were attached?  BTW, it is better if you actually post them as pictures within your reply.
mandjnev
Re: WIFI Drop Out
this is the Speed Test
