Very, very unhappy customer
- Very, very unhappy customer
- « Previous
- 1
- 2
- Next »
Re: Very, very unhappy customer
11-07-2012 6:51 PM
11-07-2012 6:56 PM
11-07-2012 7:04 PM
If you need to change it, disconnect your Internet session in the modem/router interface first and then power it down before unplugging from the line.
This helps prevent the DLM from thinking you have a dropping connection.
It would be best to confirm the phone fault is present with the phone plugged directly into the test socket without a filter at the appropriate time.
11-07-2012 7:04 PM
I've just sent you a PM with regards to the faults that you have mentioned.
11-07-2012 7:08 PM
11-07-2012 7:39 PM
Thanks for your PM back. It looks as though you have a Telephone Fault, with this type of fault, it would require an engineers visit. My advice would be to call our Customer Support Centre ASAP to get an engineer booked to have this problem resolved ASAP.
I'm happy to personally keep an eye on this for you to make sure that the fault gets cleared and that if there are any other issues, you can simply come back to me and I'll get you sorted out.
Contact Details:
From Landline: 0800 432 0200
From Mobile: 0345 432 0200
11-07-2012 10:48 PM
12-07-2012 11:09 AM
12-07-2012 11:55 AM
17-07-2012 12:38 PM
I'd like to thank Plusnet (in particular Chris) for getting this sorted and hopefully the new cable will bring joy instead of hours of frustration
17-07-2012 1:15 PM
12-08-2012 8:54 PM
Secondly, thank you to Plusnet for sorting out this issue, seeing as BT were totally hopeless.
Thirdly, since the new line has been in things haven't particularly improved. Line attenuation is the same as before and I'm still getting a lot of errors. Sync speed is down and I can't use the diagnostics at http://www.speedtester.bt.com/ to check IP profile.
Router Stats:
Uptime: 1 day, 1:56:30
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 808 / 1,664
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,600
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 1.80
Output Power (Up/Down) [dBm]: 12.5 / 17.0
Line Attenuation (Up/Down) [dB]: 31.5 / 63.5
SN Margin (Up/Down) [dB]: 15.0 / 9.5
Vendor ID (Local/Remote): TMMB / P
Loss of Framing (Local/Remote): 65,550 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,544 / 0
FEC Errors (Up/Down): 31 / 210,936
CRC Errors (Up/Down): 21 / 911
HEC Errors (Up/Down): 35 / 4,418
21-08-2012 7:28 PM
- « Previous
- 1
- 2
- Next »
