Very slow upload
- Re: Very slow upload
Very slow upload
‎18-09-2017 10:27 PM
‎19-09-2017 2:13 AM
What are your router stats showing?
This can be accessed on the plusnet hub one by typing 192.168.1.1
‎19-09-2017 2:13 AM - edited ‎19-09-2017 2:17 AM
What fibre package are you on as this can make a big difference to upload speeds
There are 2 packages available at the moment a 40/2 package and 80/20
‎19-09-2017 4:02 AM
‎19-09-2017 5:16 AM - edited ‎19-09-2017 5:17 AM
‎19-09-2017 1:34 PM
Can you let us know if you're still having the same issues please? Unfortunately the router doesn't seem connected at the moment so I'm unable to test the line.
‎19-09-2017 2:56 PM
‎19-09-2017 7:38 PM
‎20-09-2017 12:48 AM
Moderator's note:
Duplicate post removed.
Forum Moderator and Customer
‎20-09-2017 2:54 PM
Hi that's my modem back on. Upload is the same. Sometimes giving zero upload for half of the test (several seconds) then jumps up a bit. I think this is what is causing the problem with streaming. Web browsing etc is slow once something is clicked on. Getting 12 Mbps download and about 1.2 upload.
Our tests aren't showing any problems. Your upstream speed of 1.2mbps looks right on target for your connection.
However, since you've advised it's fluctuating, are you using a wired or wireless connection?
‎21-09-2017 5:40 PM
