Very Slow Upload Speed
bozzle3
I am unable to use cloud storage as my upload speed is typically 0.3mb    Contract states 1 mb.  Download is 8mb when I should be getting   11-13.     Any ideas how to get this fixed. Pretty useless as it is
3 REPLIES 3
Fixes: 334
Re: Very Slow Upload Speed
@bozzle3 Upload speed is an 'up-to' figure, and is not guaranteed.
What product are you on? I am guessing ADSL from your quoted figures.
SammyM
Fixes: 101
Hiya @bozzle3
Sorry for the delay!! We're working hard to get to you guys as quickly as possible and I really appreciate the patience you have given us!! You're a Star 🌟
I have tried to run some tests, but it's not showing an active connection and I just wanted to check with you, is the router is turned?
 Sammy M - Sheffield Team
SammyM
Fixes: 101
I have tried to run some tests again, but it's not showing an active connection and I just wanted to check with you, is the router is turned on?
