very slow the last few weeks
- very slow the last few weeks
01-10-2023 5:46 PM
the last few weeks i've had very slow broadband compared to what https://www.plus.net/member-centre/home says i should be getting, according to the site i should get "38 to 40 mbps download" but ive not seen it hit double digits in weeks. any advice? here is a speed test i did as i type this:
Re: very slow the last few weeks
01-10-2023 5:51 PM
It sounds very much like you have a problem - most likely not in your home/office environment, but more likely in the BT/OR network.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
01-10-2023 5:53 PM - edited 01-10-2023 5:55 PM
i dont have a landline, nor the ability to text or call (my phones broken and i cant fix it for a few months), should i just buy a very cheap phone when i get paid?
01-10-2023 5:59 PM
Moderators Note
This topic has been moved from Full Fibre to Broadband
01-10-2023 6:01 PM
In that case, just use this link: https://faults.plus.net to report a broadband fault.
02-10-2023 2:06 PM
Hi @Jc05 I've now raised a fault with the Suppliers. A fault was found on your line. They want to book an engineer to visit the property, can you please confirm 3 available slots and I can get the earliest one booked for you. These are Monday to Friday, between 8am and 1pm (AM) or between 1pm and 6pm (PM)
09-10-2023 3:38 PM
09-10-2023 4:15 PM
10-10-2023 1:25 PM
Cheers @Jc05, I have booked the first one which is the 16th of October between 13:00 and 18:00. I will also send an email confirmation with this on and Claudia will check back with you the next day to see how it went ![]()
17-10-2023 6:59 PM
