Value vs Extra - which is best for me??
- Re: Value vs Extra - which is best for me??
25-04-2010 6:45 PM
Hi all,
I've been with Plusnet since about August last year, no major complaints - despite a few hiccups with linespeed the team have done their best to resolve.
My question today is, I'm currently in the 8MB Value package and get a fairly decent speed of 4.1MB - I'm not unhappy with this but was recently looking into upping my speed if possible. My exchange offers ADSL2+ and gives me an estimate of 10MB. Do you think if I upgrade to the Extra 10MB line package, I'll see much of a speed increase?
My other question is for Plusnet staff - is it all possible to 'trial' the Extra package for say like a month then if I noticed much difference I would stay on that package? With no strings.
Many thanks,
Mark
Many thanks,
Mark
Message 1 of 6
(1,118 Views)
5 REPLIES 5
25-04-2010 6:50 PM
As you are currently on one of the new products you can switch back and forward without problems.
What happens if you are moved to ADSL2+ and then move back to Value is totally unclear.
If you post your full router stats (noise margin, speeds and attenuation) we might have a better idea as to the likely speed increase
Message 2 of 6
(598 Views)
25-04-2010 6:56 PM
Ok cool, sorry can you tell me how I access the stats your mentioned above. Sorry to be thick.
Cheers.
jim:quote
Cheers.
jim:quote
Message 3 of 6
(598 Views)
25-04-2010 6:59 PM
Look for your router model here http://www.kitz.co.uk/adsl/frogstats.php
Message 4 of 6
(598 Views)
25-04-2010 7:14 PM
Thanks very much, got it:
Uptime: 0 days, 1:43:24
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,104
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 30.0 / 46.0
SN Margin (Up/Down) [dB]: 23.0 / 6.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 36 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 13 / 0
FEC Errors (Up/Down): 0 / 3,132,424
CRC Errors (Up/Down): 0 / 30
HEC Errors (Up/Down): 0 / 29
Message 5 of 6
(598 Views)
25-04-2010 7:21 PM
Your current sync speed is very high for your noise margin and attenuation and may be reflected in the high FEC count.
I suspect that your current IP profile is somewhat lower than the sync speed would generate.
Rather than doing a BT speedtest at this stage can you advise what the current line speed is from here https://portal.plus.net/my.html?action=data_transfer_speed
Message 6 of 6
(598 Views)
