VPN Problems
paulby
VPN Problems
Does anyone know if there are any know issues with routing to the US?
My wife works from home and needs to VPN into her company's network (which is in the USA).  However, the VPN continually drops (9-10 times an hour).
She's been on the phone to her colleagues who are connecting via other ISPs and they haven't had any issues.
This is the only problem - the connection to "the internet" is otherwise OK.
I realise that this is probably outwith PN's control as it may be outwith their network but just wondered if anyone else was having problems or if there were known issues.
I'm not at home just now so can't do any tracerts etc.
11 REPLIES 11
James
Re: VPN Problems
Hi Paul,
There's been no known issues that we're aware of.
Might be an idea to suggest trying to reboot the router and see if this leads to an improvement in service.
paulby
Re: VPN Problems
OK James, will do.
She's going to try to get in touch with the IT folks at the US office to see if there's something up at their end but they're not in till 2pm our time.  The office in Scotland doesn't have any local IT support and, as her PC is owned by her work, I'm not allowed to check anything without the go-ahead from their IT dept.!
SteveA
Re: VPN Problems
I'm not having VPN problems - either VPN to our UK office or hopping over to the US.
That's using the Cisco VPN client
paulby
Re: VPN Problems
@SteveA
That's what I was hoping - just trying to rule out the ISP and/or routing problems.
A reboot of the router and PC seems to have done the trick for now.
DocBambs
Re: VPN Problems
I had no end of problems with my VPN into the office with my previous provider (NTHell) but it's been mostly stable since - a fixed IP address makes a huge difference. We are using Sonic Wall.
Are you using a software VPN or does the ISDN Router play a part?
Strat
Fixes: 565
Re: VPN Problems
Quote from: DocBambs
Never heard of a broken IP address before...what did you fix it with?
SORRY......Couldn't resist it.....beg forgiveness Smiley
hulls
Re: VPN Problems
I've been on VPN although admittedly only within the UK for most of the day, with no drop-outs at all.
By the way, I'd guessed the Scottish connection before you mentioned it.  It was use of the wonderful word "outwith" to mean "outside".  I've only ever heard it used by Scots friends before. Cheesy
DocBambs
Re: VPN Problems
Quote from: Dick
Granted (with pleasure!)  Grin
paulby
Re: VPN Problems
We've got a static IP and a software client provided by her company.
The VPN has been stable since the reboot.
Her IT department will keep an eye on things though.
@hulls:
Well spotted with the Scottish connection!!
dave
Fixes: 6
Re: VPN Problems
I use VPN to connect to the work network most evenings and it's always been fine. My router does though need a regular reboot as it does have a tendancy to slow down if I leave it on for weeks on end.
Dave Tomlinson
Plusnet Technology
paulby
Re: VPN Problems
I'll need to make a point of doing a regular reboot of the router - it's normally just left on all the time.
