VOIP Registration now unavailable ?
daveg6hni
Not sure if this is the correct place to post this, but overnight both of my VOIP telephone numbers have become unavailable ?
I have a SIPGate number via a Gigaset n300a box and a new number from A&A viia both the Gigaset box and also my FritzBox 7590.
So two services from different companies, the only common factor is my recently upgraded Plusnet FTTP connection ?
Now last weekend there was an issue that stopped pings being received I wonder if PN have made a change ?
Tags (3)
7 REPLIES 7
QuadT
Re: VOIP Registration now unavailable ?
There's currently a widespread plusnet intermittent outage which appears to affect DNS (regardless of DNS service used) or a routing issue.
Seems to have started just before 4am.
The default support reply on X has been updated when responding to everyone's questions this morning:
"We’re aware of a situation at the moment which is effecting a lot of customers. Currently we have no timescale to get this resolved."
Fixes: 555
https://community.plus.net/t5/Broadband/dns-block/m-p/1970442#M366045
daveg6hni
I'm not using PN DNS, I'm using 1.1.1.1 and 8.8.8.8 as they appear much faster
So did not think I would be affected, however, Internet is very slow this morning and I can't reach SamKnows to check anything...
Fixes: 555
I'm using OpenDNS and I'm still affected. Its most odd, some things now seem to be working and others not. For example, I have two voip providers Localphone & Sipgate. Localphone is registered fine but Sipgate wont register! Access to the Sipgate portal fails as well...
daveg6hni
Very strange and I can't access SamKnows or ThinkBB, but now ThinkBB is there and it is showing the same fault as last weekend, no ping, but this time to both lines I monitor, both are FTTP, one in Southend & the other in Chelmsford
Fixes: 555
... and my Sipgate registration has just come back
daveg6hni
yep both my VIOP SPs are back and I can just see on my BQM that pings are working again
