Slow Fibre Speed
Funkylady1
Slow Fibre Speed
We have just moved house and are now connected to Fibre without a phone line.
The predicted speed was 34mb + with a minimum of 22mb however on doing a speed test it is coming in at only 11mb. Can anyone advise what course of action to take? Thanks
12 REPLIES 12
Fixes: 388
Re: Slow Fibre Speed
@Funkylady1
Report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
HPsauce
All Star
Fixes: 5
Speed tests, depending how you do them, are notoriously unreliable/variable.
Have you checked (do you know how to) what speed your router is actually connected at?
Fixes: 388
@HPsauce - given what the OP posted, I still suspect a fault - if the bot doesn't find anything, then we can investigate further.
willcutforth
Fixes: 113
@Funkylady1 speed is below the Minimum speed. No obvious fault on the line. I will leave it to @jab1 and @HPsauce to help diagnose but just be aware that if we need to raise an engineer we will need to see the setup either via pictures or a system we call rescue lens where we use the phones camera to look at the setup.
 Will Cutforth
HPsauce
All Star
Fixes: 5
@jab1 is more of an expert than me but @Funkylady1 can you say what speed test you ran and what device/system/pc/phone/whatever you ran it on and how it was connected to your router?
You should be able to connect to your router by clicking on this link Basic - Status which will show the Upstream and Downstream speeds.
(As an aside, after my recent upgrade from ADSL to FTTC my main computer, which I'm using to post this, only tested at about half "expected" speed until I upgraded and reconfigured the WiFi connection in it.)
Fixes: 251
Really could do with the ADVANCED line stats as those include SNRM and line attenuation figures.
Given that this is a SOGEA service (no PTSN voice service) if there is any internal wiring from the master socket, it would be wise to remove that so that there is no chance of that degrading the broadband service.
I am assuming that if there is internal wiring, that the router is plugged into the master socket.  Plugging routers into internal telephone extensions, especially flexible, cheap D profile extension leads is a typical source of the described symptoms - no fault on line but exceptionally slow speeds.  At this juncture, data speed tests do not assist with the diagnostic process - we need to see the line sync metrics and have a description of the physical installation.
Also there is no indication herein as to if the reported speed test was performed over an Ethernet connection to the router or WiFi ... and if the latter what was the test device.  Diagnostic DATA speed tests should only be performed over an Ethernet connected device, with WiFi turned off and no other device using the internet concurrently.
Fixes: 388
I may be a little slow to reply - currently 'on holiday' with a very slow connection - but if no-one minds, as it gives us a good picture, can you @Funkylady1 follow the below , please?
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
greygit1
RescueLens is an application that only runs on 'smart' phones.
I have a mobile phone, but it doesn't have a camera. Neither does it have interwebz. It is a device designed and used to make and receive voice calls and text messages. I note a shift in Plusnet p&p's here.
Fixes: 388
Your reply is 'helpful', @greygit1 🤣
Funkylady1
So a quick update
As it’s now been more than 10 days since connection I contacted Plusnet yesterday saying that the average speed I’m getting is 14mb
The chap did a line check and said that it was banded and also there was the potential that some wire were touching either inside or outside the house.
He said he would lift the banding and that I had to wait at least 4 hours after which I had to turn off my mid for 10 seconds before turning on.
I did this this morning after 16 hours since speaking to the chap and the speed is still showing at 15mb average.
They say it can again take 10 days to settle but my question is this what is the likelihood of it improving to at least the minimum guaranteed, 22mb?
Should I get back in touch with Plusnet now or wait another 10 days?
TIA
Fixes: 388
If you post the details I requested in post #8, Community members may be able to comment/help. If you don't want Community  help - fine - but let us know.
markhawkin
Champion
Fixes: 22
@Funkylady1
Firstly is the speed test using a computer connected via a wire to the Plusnet router?
WiFi adds another complexity.
The most likely reasons for slow broadband are
1) A wiring issue in your home
2) A cable issue between your home and the green box in the street
The first one you can investigate to a degree by ensuring that the Plusnet router (and nothing else) is connected to the incoming phone socket. Often they have a part of the front that unscrews and reveals a "test socket" inside. Using that should ensure that no other internal cabling is connected,
The connection speed will be best using that socket.
If still slow on a cable connected device then it may be an external fault. You will then need to go through the fault reporting process and let that take its course.
