Usual download speed query!!
- Usual download speed query!!
Re: Usual download speed query!!
07-03-2013 1:53 PM
Thankyou to The Plusnet staff for sorting it!
I'll monitor the results over the next couple of weeks just to check there is no drop off
Cheers everyone
Jim
07-03-2013 2:10 PM
@Jimsky - Excellent news!
07-03-2013 2:35 PM
Have I spoken to soon?
07-03-2013 5:29 PM
Looks like the profile we're seeing is improving, I hope that's only a blip but if you keep seeing it happen or it's still ongoing I'd definitely update the fault ticket with that information. Hope it is fixed and works well overnight, if not I'll make sure to get the fault pushed back tomorrow morning for you.
08-03-2013 6:16 PM
Quote from: Anotherone @Cholek3
I take it from the way that Adam's posted that you've already added the missing information to the ticket.
If I'm mistaken, you can update the ticket and attached the .jpg speedtest results to the ticket (rather than using the links)
Yes, you can, but for some reason I could attach only 1 file (and there was 7 .jpg). So I posted link, but also attached .pdf with 7 screen shots. I have also got reply:
Quote So that we can investigate your fault further we need to arrange a engineer visit. Please reply to this message with 3 available timeslots for an engineers visit. The available timeslots are weekdays either between 8am & 1pm or between 1pm & 6pm. If the fault is with your internal wiring or equipment a charge of £60 will be applied
What equipment are we talking about? 60 quid? We took router out of equation. Modem is supplied by Open Reach, but it isn't mine, is it? Is there other equipment I am responsible for?
Here is a photo of my main socket, should I give it a try an disconnect those 2 "unused" cables, before engineer comes?
Regards.
08-03-2013 7:27 PM
But if you want to be happy, then remove the lower faceplate but not the top vDSL plate and leave the modem plugged in undisturbed.
The two lots of wires may be connected to the back of the removed plate. If so, just gently pull the wires vertically out of each terminal, just coil them in pairs (blue pair, orange pair) separately for each cable and tuck them back out of the way at the rear of the socket, or remove the cables completely if they will pull out without disturbing the rest of the socket.
If they seem to be connected to anything else then leave it for the engineer to sort out as they shouldn't have been connected anywhere else at installation of the Fibre. Or if you want them pulled out and they wouldn't, when the engineer unplugs the modem to do some tests, ask him if he'd pull them out.
The £60 remark is just the standard clause to ensure that everyone has carried out the tests and checks that Faults have required. It's not really applicable with a recent Fibre install as you've pointed out. The Modem is Openreach's, you've checked direct to the modem, the router is under warranty anyway, so no worries.
08-03-2013 8:40 PM
08-03-2013 9:00 PM
08-03-2013 10:47 PM
08-03-2013 10:51 PM
10-03-2013 12:12 AM
10-03-2013 12:29 PM
Quote from: Cholek3 I removed Open Reach panel accidentally.
Well I hope it hasn't messed up your BT IP Profile
The first picture (0593a) is the relevant one, except that the wires connected to the back of that plate aren't in the picture. Not to worry, let me phrase it like this - if the only socket in the house that you are using or want to use for the phone is the one on the front of that plate, then you can take the wires off the back of it (they don't feed the plate - they feed the remote socket). The plate is fed by the moulded plug on the rear of the plate that goes into the test socket that's exposed when the plate is removed. Hope that's clearer now
10-03-2013 1:48 PM
And yes, IP profile change slightly, from 74.54 to 73.59.
10-03-2013 1:58 PM
10-03-2013 5:41 PM
