Being DDoSed
tonytoon
Being DDoSed
Hello,
I was contacted on Skype by someone who claims himself as a hacker and after being called many names, I discovered my connection dropped. Who was it? Him.
I am 95% sure I was DDoSed as my 70mb/s down speed dropped to 20 and my up speed was basically 0.
He stopped, called me many more names and threatens to continue dosing me because of my 'misleading online-games alias.'
I am not sure what to do now, suggestions?
(He uses a VPN, his real ip is masked.)
jslane
Re: Being DDoSed
I don't think there's much you can do other than block and ignore him, unless plusnet are able to mitigate DDoS attacks for you. I doubt it unless you're on a business connection.
RPMozley
Fixes: 5
Re: Being DDoSed
One question I'd like to ask is, do you have a misleading online-games alias?
That's RPM to you!!
tonytoon
Re: Being DDoSed
It's Ult1m4t3H4ck3r, i used to mod games. I've had that for a few years and never had any problems with it, except the occasional "why that name?"
DrDave
Re: Being DDoSed
Cool story bro!  Cheesy Crazy
Fixes: 160
Re: Being DDoSed
If you can track the IP address the DOS is coming from (assuming it's just 1 and his) then you can use an IP lookup site and report him to his ISP, there should be an abuse contact address for them.
 Chris Parr
 Plusnet Staff
Fixes: 6
Re: Being DDoSed
Quote from: tonytoon
I'm sure if you contact his VPN provider, they will take action.
May help to copy any report from your routers log file and send that as evidence.
Wulfy
Re: Being DDoSed
Quick question, does the plusenet firewall (at plusnets end not a software firewall) allow for such things to be blocked?
