Using Plusnet Router with other providers
- Using Plusnet Router with other providers
23-01-2012 1:27 PM
can i use the plusnet thomson tg585 v8 router with other internet providers or will it be blocked?
Message 1 of 2
(3,510 Views)
1 REPLY 1
Re: Using Plusnet Router with other providers
23-01-2012 1:35 PM
HI ismael19,
It can be used with other providers, but make sure you read their Ts&Cs as some don't allow you to use them and some will only let you connect with a mac address that they have registered on their systems (i.e. their equipment) If you're passing it on to someone else make sure you remove your username and password beforehand, too!
Jojo
Jojo
Message 2 of 2
(3,172 Views)
