Using Plusnet Router with other providers
ismael19
can i use the plusnet thomson tg585 v8 router with other internet providers or will it be blocked?
1 REPLY 1
jojopillo
Re: Using Plusnet Router with other providers
HI ismael19,
It can be used with other providers, but make sure you read their Ts&Cs as some don't allow you to use them and some will only let you connect with a mac address that they have registered on their systems (i.e. their equipment) If you're passing it on to someone else make sure you remove your username and password beforehand, too!
Jojo Smiley
