Using Laptop with 42" HDTV
- Using Laptop with 42" HDTV
02-06-2008 2:07 PM
PC Details:
Display
Display Type: 17" TFT
Max Resolution: 1440 x 900 ( WXGA+ )
Widescreen Display: Yes
Features: Crystal View
Video
Graphics Processor / Vendor: NVIDIA GeForce Go 6800 PCI Express x16
Video Memory: DDR SDRAM - 256 MB
Audio
Audio Output: Sound card
Compliant Standards: AC '97
Audio Input: Microphone
Re: Using Laptop with 42" HDTV
02-06-2008 2:16 PM
What external video connectors do you have on the HDTV?
Does the HDTV come with any video cables?
What is the make and model of the HDTV?
03-06-2008 9:14 AM
The TV is a Aldi Medion 42" HDTV with video connections red yellow blue
The Labtop is as prevously specified
cannot provide specific model no for TV as not at home at present
Regards
Harry
03-06-2008 10:48 AM
As Peter says, it depends what output you have from your laptop.
Do you have VGA? DVI? S-Video?
Assuming you have a VGA-out and Scart-in £59.99, http://www.maplin.co.uk/module.aspx?ModuleNo=37141&doy=3m6
If you have S-Video out and Scart-in, you could opt for one of these: http://www.maplin.co.uk/module.aspx?ModuleNo=35910&doy=3m6
If you have VGA-Out and only the component in, you could opt for a cable from these guys. £35 - look on the 'component' tab. http://www.projectorpoint.co.uk/projector-accessories/audio-visual-cables.html
I've not searched for a DVI to component cable, as I don't think its likely your Amilo notebook will have one of these - if it does, they are available too.
03-06-2008 11:18 AM
3 2
4
6 5
7
9 8
10
1 = Modem port
2 = DVI-I connector
3 = S Video out socket
4 = LAN port
5 = FireWire port
6 = USB ports
7 = CIR interface
8 = Headphone port/SPDIF
9 = Microphone port/Line In
10 = USB port
Connecting an external monitor
An external monitor can be connected to the notebook.
► Switch off the notebook and the external monitor.
► Connect the data cable of the external monitor to the DVI-I connector of the notebook.
i
If you want to connect an analogue monitor, first connect the monitor adapter provided to
the DVI-I connector of your notebook.
► First switch on the external monitor and then the notebook.
Using the Fn + F4 key combination you can switch back and forth between the external monitor
and the LCD screen.
You can display the same picture on the external monitor and the LCD screen simultaneously.he Laptop Detail:
03-06-2008 11:25 AM
You want either a DVI-I to Component cable, or you want a VGA to Component cable if you use the adaptor referenced in the instructions.
03-06-2008 11:28 AM
If your TV has a DVI input that would be preferable, but somehow I doubt it will have.
Neither will connect sound, you'll need to do that through a separate cable if you need it.
03-06-2008 11:38 AM
As @Daddies says, you'll need toconsider sound seperately. If you want it, your notebook should have a 3.5mm stereo headphone socket - there are two of these on the rear of your TV too if I'm looking at the right one. Just connect a 3.5mm Stereo Male to Male cable between the two for sound. (Alternatively if you have surround sound seperate, you can link the sound directly into that.)
03-06-2008 11:49 AM
03-06-2008 12:04 PM
Its still the one to go for, unless you can afford the series 6 100Mhz sets.
03-06-2008 1:10 PM
Any chance of supplier/detail?
Regards
Harry
03-06-2008 1:22 PM
Assuming you still have it, I'd go for the VGA cable (You'll want a male to male one and you'll need to decide how long you want it to be.)
Maplin is as good a place as any for stuff like this. http://www.maplin.co.uk/module.aspx?ModuleNo=97367&doy=3m6
A quick Google for Male to Male VGA Cable yields some alternatives too.
03-06-2008 2:07 PM
Harry
04-06-2008 5:40 PM
ive used this site on e bay for loads of cables. very good service quality and price too.
http://myworld.ebay.co.uk/all_4_lauren_uk/
hope this helps
r
craig
