Using Laptop with 42" HDTV
conductivity333
Please advise how to "hook up" my AMILO Fujitsu Siemens  M3438G Pentium Labtop with 42" HDTV
PC Details:
Display
Display Type: 17" TFT
Max Resolution: 1440 x 900 ( WXGA+ )
Widescreen Display: Yes
Features: Crystal View
Video
Graphics Processor / Vendor: NVIDIA GeForce Go 6800 PCI Express x16
Video Memory: DDR SDRAM - 256 MB
Audio
Audio Output: Sound card
Compliant Standards: AC '97
Audio Input: Microphone
13 REPLIES 13
Peter_Vaughan
Re: Using Laptop with 42" HDTV
What external video connectors do you have on your laptop?
What external video connectors do you have on the HDTV?
Does the HDTV come with any video cables?
What is the make and model of the HDTV?
conductivity333
Peter
The TV is a Aldi Medion 42" HDTV with video connections red yellow blue
The Labtop is as prevously specified
cannot provide specific model no for TV as not at home at present
Regards
Harry
Presumably you will have a scart socket?
As Peter says, it depends what output you have from your laptop.
Do you have VGA? DVI? S-Video?
Assuming you have a VGA-out and Scart-in £59.99, http://www.maplin.co.uk/module.aspx?ModuleNo=37141&doy=3m6
If you have S-Video out and Scart-in, you could opt for one of these: http://www.maplin.co.uk/module.aspx?ModuleNo=35910&doy=3m6
If you have VGA-Out and only the component in, you could opt for a cable from these guys. £35 - look on the 'component' tab. http://www.projectorpoint.co.uk/projector-accessories/audio-visual-cables.html
I've not searched for a DVI to component cable, as I don't think its likely your Amilo notebook will have one of these - if it does, they are available too.
conductivity333
This is tPorts
1
3 2
4
6 5
7
9 8
10
1 = Modem port
2 = DVI-I connector
3 = S Video out socket
4 = LAN port
5 = FireWire port
6 = USB ports
7 = CIR interface
8 = Headphone port/SPDIF
9 = Microphone port/Line In
10 = USB port
Connecting an external monitor
An external monitor can be connected to the notebook.
► Switch off the notebook and the external monitor.
► Connect the data cable of the external monitor to the DVI-I connector of the notebook.
i
If you want to connect an analogue monitor, first connect the monitor adapter provided to
the DVI-I connector of your notebook.
► First switch on the external monitor and then the notebook.
Using the Fn + F4 key combination you can switch back and forth between the external monitor
and the LCD screen.
You can display the same picture on the external monitor and the LCD screen simultaneously.he Laptop Detail:
So there is your answer:
You want either a DVI-I to Component cable, or you want a VGA to Component cable if you use the adaptor referenced in the instructions.
HPsauce
DVI-I supports both Analogue and Digital signals.
If your TV has a DVI input that would be preferable, but somehow I doubt it will have.
Neither will connect sound, you'll need to do that through a separate cable if you need it.
Looking at the spec on Aldi's website, it appears the TV has a VGA input, so the cheapest option is probably a VGA-VGA cable, and use the DVI-VGA adaptor that came with your notebook.
As @Daddies  says, you'll need toconsider sound seperately. If you want it, your notebook should have a 3.5mm stereo headphone socket - there are two of these on the rear of your TV too if I'm looking at the right one. Just connect a 3.5mm Stereo Male to Male cable between the two for sound. (Alternatively if you have surround sound seperate, you can link the sound directly into that.)
HPsauce
The other thing to beware of, to avoid disappointment, is that the VGA inputs on many TV's are limited in resolution and/or aspect ratio. You may only get 4*3 not widescreen and 800*600 at best. Also the screen refresh rate will need to be set to something the TV will accept, probably no higher than 60Hz.
Yeah, I was worried about that with mine, but my trusty Samsung (Series 5) didn't let me down.
Its still the one to go for, unless you can afford the series 6 100Mhz sets.
conductivity333
Is the VGA to VGA cable the answer then?
Any chance of supplier/detail?
Regards
Harry
So long as you still have the adaptor to go between your laptop and the cable (it'll likely be a couple of inches long with a male DVI plug and a female VGA socket on it).
Assuming you still have it, I'd go for the VGA cable (You'll want a male to male one and you'll need to decide how long you want it to be.)
Maplin is as good a place as any for stuff like this. http://www.maplin.co.uk/module.aspx?ModuleNo=97367&doy=3m6
A quick Google for Male to Male VGA Cable yields some alternatives too.
conductivity333
Thanks for your help  will try it tomorrow
Harry
craig_p
hi
ive used this site on e bay for loads of cables.  very good service  quality and price  too.
http://myworld.ebay.co.uk/all_4_lauren_uk/
hope this helps
r
craig
