Useful software tool for router
- Re: Useful software tool for router
29-08-2013 1:49 PM
These are very powerful software tool for any broadband router including BT Openreach Huawei HG610, HG612 & HG622. Try it. As I had try it on my Netgear DGND3700v2 and love it. They show everything full features far better than DMT Tool and RouterStats.
http://www.s446074245.websitehome.co.uk/features.html
Interesting of my chart showing of averages on my line errors below:
Message 1 of 7
(3,009 Views)
6 REPLIES 6
29-08-2013 1:55 PM
This may be an error but it states
So not for 64 bit Windows
Quote The program is available for four operating systems:
32-bit Linux v3.9
64-bit Linux v3.9
32-bit Windows v3.9
Raspberry Pi v3.9
Message 2 of 7
(1,044 Views)
29-08-2013 1:56 PM
I got 64 bit Windows 7 and it does work!
See below!
See below!
Message 3 of 7
(1,044 Views)
29-08-2013 4:03 PM
Must be running in 32 bit mode then. If you look at the process in Task Manager it should have a '*32' on the end?
Message 4 of 7
(1,044 Views)
29-08-2013 4:14 PM
Yes it running in 32 bit mode. But it will let you installing on the 32 or 64 bit windows anyway. The next version 4.0 will be including 64 bit mode soon.
Message 5 of 7
(1,044 Views)
29-08-2013 4:20 PM
Do you happen to know what it does to the telnet timeout on the Technicolor routers
Message 6 of 7
(1,044 Views)
29-08-2013 6:32 PM
Quote from: goldenadsl These are very powerful software tool for any broadband router
It's only for routers based on Broadcom chips.
Message 7 of 7
(1,044 Views)
