Usage
temp
Usage
How can I check my internet usage?
I'm moving and might have to be without a phone line for a while. Looking into buying a wireless router using payg data cards and wondering how much that's going to cost to replace broadband.
8 REPLIES 8
Fixes: 389
Re: Usage
One way is to hope one of the Plusnet Help Team spot this and provide the information. The other way, providing you have not had a re-sync for a long time is to check on you Hubs Help Desk - that will show your up-time and upload/download totals - divide the combined U/L and D/L figure by the number of days, which should give you a daily average.
Fixes: 480
Re: Usage
@temp
I suspect that you will find that Plusnet no longer record usage on unlimited connections.
If you can receive O2 mobile then consider a GiffGaff SIM.  https://www.giffgaff.com/sim-only-deals?ggCampaign=PS_G_Brand_Exact_Brand-Pure&gclid=EAIaIQobChMIyYm...  If works on a monthly contract and they have excellent deals on 'Goodybags' at the moment. You can change the Goodybag from one amount to another on a monthly basis and renew one if it runs out of data whenever you like. The only rule is that they expire after a month. I would start small and see how long it lasts and if it runs out after say a couple of weeks then buy one for twice the capacity.
I use GiffGaff in my mobile phone, which I rarely use. I keep a float of money in the account but don't have a continuous Goodybag, instead paying the more expensive non Goodybag rate if I need to make a call. If I am going away and know I will need to make calls and/or use data I simply take a Goodybag for one month, it's very flexible. In this case the only rule is that you have to make a call/use some data every 6 months to keep the number live.
temp
Re: Usage
the hub seems to only collect my data from this morning and then reset (probably because I switch off at night?) but that's enough to get an idea. Thanks!
Fixes: 389
Re: Usage
@temp - I would seriously suggest you don't switch the Hub off at night. Its power consumption is minimal, it is designed to be  on 24/7  and you could induce the DLM to think you have a problem, when you don't.
adam945
Fixes: 113
Re: Usage
Hello @temp
The graph below shows how much data you've both uploaded and downloaded over the course of the month for November. Hopefully this gives you some sort of idea Smiley
 Adam
 Plusnet Help Team - Leeds
temp
Re: Usage
I officially declare you the PlusNet Champion. Thumbs_Up
Fixes: 1,665
Re: Usage
Adam may be Plusnet Champion, but I'll always be Plusnet Gandalf. Cheesy
adam945
Fixes: 113
Re: Usage
Credit where it's due, it was actually @Gandalf who showed me how to access broadband usage data some time ago!
More tan happy to help @temp  Smiley
 Adam
