Upload speed
- Upload speed
Upload speed
09-05-2024 1:33 PM
I had a fault and was getting bad download and upload speeds . Openreach engineer fixed today. I am getting 0.443 kbps upload speed in plusnet hub. I have 2.5mbps download guaranteed and 1mbps upload guaranteed. Is there any way to increase upload speed without needing an engineer again?
Message 1 of 2
(623 Views)
1 REPLY 1
Re: Upload speed
09-05-2024 6:08 PM
Hi @Andrei120
Unfortunately, we can't guarantee upload speed but I can see what's causing the issue as your upload speeds weren't fully reset.
I've requested the reset again for you and this should improve them soon
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Message 2 of 2
(566 Views)
