Upload and download speeds
Martin123453
Hey I'm not sure how else to get this sorted so iv come here, I want to increase my upload and download speed and I know only plusnet can do it my current upload speed is something around 0.34 is there any way of increasing this?
Fixes: 58
Re: Upload and download speeds
It rather depends
First question - if you put your phone number in http://usertools.plus.net/exchanges/ what does it say about WBC on 21CN
Second question please post the router stats as asked for here http://community.plus.net/forum/index.php/topic,96155.0.html
Plusnet Staff
Plusnet Staff
Your line was capped. I've asked BT to remove it, and you'll get the new speeds by tomorrow morning.
 Tony
 Plusnet Support
Martin123453
Quote from: plusnettony
im wondering if it could go any higher? as im trying to live streem aome video games but its lagging all the time
Line Attenuation (Up/Down) [dB]: 21.0 / 43.5
SN Margin (Up/Down) [dB]: 5.4 / 11.4
Bandwidth (Up/Down) [kbps/kbps]: 1,147 / 6,312
download speed 5.30 mbps
Upload 0.90 mbps
Plusnet Staff
Plusnet Staff
I'm afraid that's about the level to expect on this technology. Fibre does appear to be available for you, and that should drastically increase the up (and down)load speeds.
 Tony
 Plusnet Support
Martin123453
I'm currently on unlimited broadband paying around £18 a month, how much would I be looking at for the upgrade?
Plusnet Staff
Plusnet Staff
Fixes: 159
The standard costs for our fibre services are either £14.99 (plus line rental) or £19.99 (plus line rental). However our customer options team can quite often sort out a good deal for you if you get in touch on 0800 013 2632 or 0330 123 9197.
 Chris Parr
 Plusnet Staff
