Upload Times Out
- Upload Times Out
Upload Times Out
28-05-2014 6:51 PM
Hi. My daughter failed to submit a University assignment today as the upload kept timing out. As it was a PDF document of only 3.1 Mb this seems extreme (to say the least). The Uni is threatening to dock 10 marks for late submission we are trying to find out what the reason is.
The Uni IT Help Desk is blaming our ISP speeds but the Speed Tester shows an upload speed of 0.4mbps which ought to be adequate (d/l is 6.1 mbps).
We tried a good half-dozen time between Noon and 3pm. Can you please see if there is a reason for this issue?
Hope you can help.
Nick
Hope you can help.
Nick
Message 1 of 2
(499 Views)
1 REPLY 1
Re: Upload Times Out
28-05-2014 7:06 PM
Hi Nick,
I've fully checked your connection and can't find any issues to indicate there's a problem, further more as you're able to upload to the document to google docs that suggests the issue is on the universities servers.
I've posted the test results on your support question you've raised to us if you need to refer back to them.
Hope you get it sorted!
Regards,
Martin
Regards,
Martin
Message 2 of 2
(330 Views)
