Upload Speed Just Halved!
Polyphone
I've only been with Plusnet for a few months (on part fibre (80/20) but have had decent (relatively) download speeds of approx 74Mbps and upload of around 18Mbps.
While working at home today, my connection dropped for a few seconds and has reconnected at 79.99 download and 8.3 upload ... my actual upload speed is now about 8!
Has something happened on the network?
Should I just try a router reboot?
3 REPLIES 3
Fixes: 472
Re: Upload Speed Just Halved!
Moderator's note:
Thread moved from Tech Help to Broadband
Fixes: 472
@Polyphone    Welcome to the Plusnet Community Fora.
You could try. If that doesn't help leave the Hub powere up for half an hour or so and try a factory reset of the Hub. Push a paperclip or similar in the reset hole. Keep the switch closed until you get a green light. It will then take several minutes to re-establish a connection.
If that doesn't work we first need to establish whether you are testing over a wired Ethernet or wireless connection to the Hub. If wireless, can you test using an Ethernet cable?
Fixes: 241
Sight of the full line stats would be helpful.
What you describe could be caused by narrow spectrum RFI impacting the US carrier tone bins.
