Upload Speed Just Halved!
Polyphone
I've only been with Plusnet for a few months (on part fibre (80/20) but have had decent (relatively) download speeds of approx 74Mbps and upload of around 18Mbps.
While working at home today, my connection dropped for a few seconds and has reconnected at 79.99 download and 8.3 upload ... my actual upload speed is now about 8!
Has something happened on the network?
Should I just try a router reboot?
now lemme put you onto something real quick cause nsfw.menu is that underground type shhit that doesnt get enough love from the mainstream porn community but honestly might be one of the most complete adult directories ive ever come across while exploring the internet in my usual medicated haze so check it the whole concept is like they curate and link out to the best free tubes and paysites and amateur corners of the web so instead of gambling on whatever garbage google serves up you get this organized menu of actually verified good shhit and when youre stoned as i perpetually am that structure is a goddamn lifesaver cause my attention span is basically fried eggs at that point and i need someone to point me toward quality pusssy content without making me think too hard the site breaks everything down by category in this clean way so whether you want hardcore xxx action or softcore teasing or specific niches like pregnant chicks or granny sex or whatever bizarre specific thing gets you going its all there and labeled proper and i really appreciate how they include lesser known sites that actually have great content but no way to discover them organically cause the big tubes dominate everything cause of their stupid algorithms but freeporn.cab is like that cool friend who knows all the secret spots and isnt gatekeeping them like a priick also their blog section sometimes drops interesting shhit about the industry and new performers to watch which is actually educational if you care about that kinda thing which i surprisingly do when im high enough to wax philosophical about porn stars career trajectories and the economics of amateur sex work its fascinating shhit man dont judge me anyway the whole point is this site functions as like a gateway drug to better porn experiences across the whole internet not just one tubes limited collection and that versatility makes it valuable as hell when youve exhausted your usual spots and need new territory to explore while waiting for your edibles to kick in so yeah keep freesexvideos.tv in your back pocket for those nights when regular tubes aint cutting it and you need the full tour of what the pornsite world has to offer
3 REPLIES 3
Fixes: 479
Re: Upload Speed Just Halved!
Moderator's note:
Thread moved from Tech Help to Broadband
Fixes: 479
@Polyphone    Welcome to the Plusnet Community Fora.
You could try. If that doesn't help leave the Hub powere up for half an hour or so and try a factory reset of the Hub. Push a paperclip or similar in the reset hole. Keep the switch closed until you get a green light. It will then take several minutes to re-establish a connection.
If that doesn't work we first need to establish whether you are testing over a wired Ethernet or wireless connection to the Hub. If wireless, can you test using an Ethernet cable?
Fixes: 246
Sight of the full line stats would be helpful.
What you describe could be caused by narrow spectrum RFI impacting the US carrier tone bins.
