Upgraded to Premium - is 3.2mb all i can expect download speeds
- Re: Upgraded to Premium - is 3.2mb all i can expec...
- « Previous
- Next »
Re: Upgraded to Premium - is 3.2mb all i can expect download speeds
16-01-2010 10:53 AM
Using the WIFI connected PC to view the router stats page is absolutely fine.
Message 31 of 38
(372 Views)
16-01-2010 2:26 PM
Ok thanks have moved the router and logging stats now. Will post up in a 30m the stats. I take it that this will give enough info?
Cheers for all the help
Kwack
Kwack
Message 32 of 38
(372 Views)
16-01-2010 2:50 PM
Stats plugged into Master Socket
Uptime: 0 days, 0:26:23
Modulation: G.992.1 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,992
Data Transferred (Sent/Received) [KB/KB]: 509.00 / 872.00
Output Power (Up/Down) [dBm]: 11.5 / 19.0
Line Attenuation (Up/Down) [dB]: 26.0 / 46.0
SN Margin (Up/Down) [dB]: 20.0 / 6.5
Vendor ID (Local/Remote): TMMB / µ
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 27 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 71
HEC Errors (Up/Down): 0 / 52
Message 33 of 38
(372 Views)
16-01-2010 3:07 PM
I assume by the master socket you mean the test socket behind the removable lower section. If so it looks not too different to the last good results from your normal socket.
The good thing is that your default noise margin is definitely 6dB.
I am guessing here but I think that after the engineer fixed the problem on the 24th December your line stabilised with very few errors and somewhere between the 5th and 12th of January your default noise margin was automatically dropped from 15dB to 6dB hence the speed increase.
The only thing left to check is whether the router holds sync overnight - you could watch it in your normal socket if that would be more convenient although the results from the test socket would also be interesting.
Message 34 of 38
(372 Views)
16-01-2010 3:42 PM
Yep this was in the test socket behind the cover.
It is good that this looks more acceptable now. Plusnet did advise that the stats were not that different from my internal sockets.
I will need to plug back into my normal socket as I have no phone at moment with it being plugged into the test socket.
My only question would be whether it is worth moving to ADSL2 for the increased speeds.
I will post up some more stats tomorrow.
Thanks for all the assistance in this. It is much appreciated
Kwack
Kwack
Message 35 of 38
(372 Views)
16-01-2010 3:43 PM
Lets wait for tomorrows stats but at present I would say yes
Message 36 of 38
(372 Views)
16-01-2010 3:56 PM
Quote from: kwack worth moving to ADSL2 for the increased speeds.
You'd probably only get another 1mbps or so at best, plus potentially some or all of the "issues" that plague ADSL2+
![Undecided Undecided](/html/@B2520ED9758574DA4DA10314C4B1AB94/images/emoticons/undecided.gif)
Message 37 of 38
(372 Views)
22-01-2010 8:49 PM
Made the decision to move to ADSL2. This is scheduled for 24 Jan. And they sent me a new router for this which I am very pleased with.
Anyway stats before I move across are as follows;
Uptime: 0 days, 17:00:28
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,064
Output Power (Up/Down) [dBm]: 11.5 / 18.5
Line Attenuation (Up/Down) [dB]: 26.5 / 46.0
SN Margin (Up/Down) [dB]: 19.0 / 9.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 2 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 94 / 0
CRC Errors (Up/Down): 30 / 1,274
HEC Errors (Up/Down): 16 / 537
Hopefully the move across will go smoothly
Thankd for all the assistance on this.
Kwack
Kwack
Message 38 of 38
(372 Views)
- « Previous
- Next »
