Upgrade
FIXEDTopic Options
- Full Fibre
- Upgrade
2 hours ago
Currently I am on the 500mbps plan, if I upgrade to the 900mbps what happens, does an engineer get re-sent out or do I just restart my router box, is there any downtime, etc?
Fixed! Go to the fix.
3 REPLIES 3
2 hours ago
@gemscl86 A speed upgrade involves no engineer, and AFAIK, needs no action from you.
Re: Upgrade
an hour ago
Moderator's note:
Thread moved from Broadband to Full Fibre
Re: Upgrade
an hour ago
