Under 1mbps Problem ?
- Re: Under 1mbps Problem ?
29-06-2009 8:01 PM
Hello
I seem To be Getting Under 1mbps I did a at tests at the BT Broadband tester
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 869 kbps
More Info
I am using Ethernet cables On my modem router to the computer.
Router is directly Pluged into the Phone Socket
There is only one Phone socket
Using Plusnet pro
Switched From AOL
More Info
Using Plusnet pro
Switched From AOL
Message 1 of 7
(1,133 Views)
6 REPLIES 6
29-06-2009 8:07 PM
welcome to the forums
Your BT profile is good, what does your pn one say here https://portal.plus.net/my.html?action=data_transfer_speed
also what about a speed test here http://www.mybroadbandspeed.co.uk
the bt speedtester throughput is a poor measure pf throughput at the moment.
Message 2 of 7
(510 Views)
29-06-2009 8:09 PM
Message 3 of 7
(510 Views)
29-06-2009 8:11 PM
Ah ok there is your problem, your 1000 should match the 7150 on the BT speedtester.
Can you raise a ticket through the portal and then post the ticket id back here and one of the PN staffers might pick it up too.
Message 4 of 7
(510 Views)
29-06-2009 8:28 PM
Faults checker has just Started and i have to wait For atleast 2 hours.
Thanks for the Help
Ticket ID: 29235549
Thanks for the Help
Ticket ID: 29235549
Message 5 of 7
(510 Views)
30-06-2009 9:30 AM
Morning
I've just changed your profiled speed to 7150Kbps. If you try rebooting your router, you should notice a considerable improvement in your speed.
Message 6 of 7
(510 Views)
30-06-2009 2:33 PM
Estimated line speed:
8 Mbps - Checked on 2009-06-13 22:26:41
Current line speed:
7150
Actual IP throughput achieved during the test was - 5481 kbps
Thanks Guys took the stress out of me Since i got a tourment To catch on.
Message 7 of 7
(510 Views)
