Unable to change DNS Server setting on Technicolor TG582n Router
fosbie
I've read the details in the page below to try and change my dns server setting using the telnet interface but although I can add new ones, it won't allow me to remove old ones, can anyone help?
http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
This is the result of my efforts from the telnet window, what am I doing wrong?
{admin}=>dns server route list
DNS Server Entries:
  DNS Server    Source                Label              Metric Intf        State  Domain
D 212.159.6.9                                            10    Internet      UP      *
D 212.159.6.10                                          10    Internet      UP      *
{admin}=>dns server route delete dns=212.159.6.10
Failed to delete route.
{admin}=>dns server route delete dns=212.159.6.9
14 REPLIES 14
Oldjim
Resting Legend
Fixes: 63
Re: Unable to change DNS Server setting on Technicolor TG582n Router
According to the manual http://wiki.aa.org.uk/images/3/33/TG582n_CLI_Guide_v1.0_public.pdf ; it should work
A thought - it may not be possible to delete the automatic servers and in this case you would need to add the new server with a lower lower metric and just leave the old ones unused
itsme
Is it because they have been set up by DHCP? So they are not permanent DNS servers but the ones that are being used.
HairyMcbiker
All Star
Fixes: 21
Try going through the menu system rather than the cli.
from the telnet prompt enter menu
then navigate to dns route etc
I just did it on my HH2 which has a Thompson f/w.
You might need to add the intf option for it.
fosbie
Thanks for the suggestion, didn't know about the Menu.
I'm almost there, but can't figure out how to select OK on the screen below, my cursor is in the text entry fields and I can't move it down to OK.  If I press the cursor arrows it just loops through dns, domain and intf, and if I press enter it just edits whichever field I'm on.
┌─────────────────────────┤ dns server route delete ├─────────────────────────┐
│dns := 212.159.6.9
│[domain] := *
│[intf] := Internet
│The interface associated with the DNS entry or DNS Template.
│                <Ok>                                <Cancel>
fosbie
Quote from: Oldjim
I did try that with a metric of 1 and 2 and leaving the others at 10 and 10, but didn't seem to have any effect.  Might need to try it again with a flush first though.  Will let you know.
fosbie
Quote from: fosbie
│dns := 212.159.6.9
│[domain] := *
│[intf] := Internet
│                 <Ok>                                <Cancel>
OK, I worked it out.  It's the tab button.
fosbie
Thanks for all your suggestions.  I've worked it out now.  I just needed to do a flush which I did via the menu.  That cleared out the old dns servers so that I could add in the new ones.
HairyMcbiker
All Star
Fixes: 21
Sorry I forgot about the tab to switch to the ok/cancel. It has become second nature to me that I just plain forgot that others don't know about it.
So what did you change the dns servers to? Google or opendns?
fosbie
I went with OpenDNS for their parental controls, although I'm now annoyed that their parental controls don't offer the same level of control as they did when I was using my old Netgear router.
prichardson
OpenDNS parental controls come with the additional options through their VIP service.
If I recall, that costs around £12.36 for the year, though you can get 50% off that if you first like them on Facebook with the following link to unlock the VIP code.
https://www.facebook.com/OpenDNS?v=app_140149346021719&rest=1
Then apply the code whilst logged into OpenDNS with the following link.
https://store.opendns.com/get/vip-home
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: fosbie
I looked at this once but I couldn't see that there was anything to prevent a smart kid from overriding the router DNS settings on their own device.
prichardson
Not by default there isn't.
You could however set the firewall in the router to a custom setting, and within that setup a rule to block UDP port 53 on the WAN interface to anything other than the OpenDNS servers.
fosbie
The features I was after are apparently only available with a netgear router as they have to install some code on the router itself.
When it was working I was able to change content filtering profiles on a timed schedule and enable bypass accounts on specific windows users.
I'm not too bothered about my kids entering their own dns settings, they are too young to know about that sort of thing.  More worried about them clicking on something by accident.
mrfawlty
Quote from: P
Couldn't see where you mean on the firewall page  - could you enlighten me please?
