Tips for improving WIFI connection
- Re: Tips for improving WIFI connection
02-09-2010 11:30 PM
My Xbox and 2nd PC are downstairs and are connected via home network so that I can view pictures etc on teh TV. The connection always shows very poor performance and sometimes drops the connection
Is there anyway I can impriove trhe range/output so that the performance is stable?
Kwack
03-09-2010 12:10 AM
Where is the BT master socket/incoming line?
03-09-2010 12:26 AM
1) Ditch the wireless and use 200Mbit mains network adaptors - http://www.devolo.co.uk/consumer/dlan-mains-supply-network-fastest-200-mbit.html?l=en for example http://www.pcworld.co.uk/gbuk/devolo-dlan-200-aveasy-starter-kit-2x-home-plug-av-adapters-uk-0093920...
2) Upgrade all your wireless-G aerials with higher gain antennas - http://cgi.ebay.co.uk/9dbi-Booster-WiFi-Wireless-Router-Antenna-Aerial-SMA-/360296611968?pt=UK_Compu...
3) Upgrade your router firmware to give better wireless range - http://www.dd-wrt.com/site/index
4) If you are running wireless-G, then upgrade to wireless-N for huge range improvement. - you could do this with wireless-N access points as these will be cheaper than wireless-N routers.
03-09-2010 1:02 AM
1. Place your router higher up - this may be sufficient!
2. Get an extension aerial for PC etc (with a "pigtail" kind), assuming that you have removable aerials on the PC and X-box. Check connector types before buying.
Position aerials above PC etc.
3. If you want to watch video on your TV, wireless is too slow for on demand type usage. You need some kind of wired connection.
03-09-2010 8:38 AM
Quote from: A
Simply not true anymore, although it may be your experience on a slower network.
As said above though you need to think about your arials, router position and sources of noise like microwaves, fridges TV's etc.
I moved my USB type arial from one side of my tv to the other and the signal went form 81Mbps to over 180 just with that simple adjustment, all it cost me was a USB extender cable.
03-09-2010 8:44 AM
I would agree with that, I am now streaming DVDs at 720p (as DivX) over my wireless-G with no problems, and no noticeable slow downs for anyone else.
Also consider that BBC iPlayer streams at a couple of Mbit over broadband, which is next to nothing over a 54Mbit wireless link.
03-09-2010 1:01 PM
Just to clarify as my post may have been slightly misleading. When connecting my Xbox to WiFI the connection to download games, view films via Internet is pretty good.
It is when I link into Media centre from Xbox to PC - i.e to see pictures that the connection is very poor?
There seems to be some dis-connect here as Internet is fine but readign files from PC isnt?
Is this more of a home network setting rather than a broadband setting
This is teh first time I have set up a hom network so maybe I have missed something
Kwack
03-09-2010 3:13 PM
Replace at least one leg with wire.
03-09-2010 9:58 PM
Would switching to a 802.11n router help in any way or is there a cheaper way of obtainign this. I curently have a Thomson 585v7
Kwack
04-09-2010 3:20 PM
This is for N 300 not N150 though which may only be marginally better if it's noisy where you are, so look for DUAL BAND.
my TV set up was receiving 18-36Mbps on G (Router upstairs - TV Downstairs)
I got a Netgear Rangemax DGND3300v2 with 3100v2 USB Arial - on checking this morning it's manged to get 245Mbps with careful positioning out of a max 270Mbps.
04-09-2010 8:13 PM
So if I switch to a 802.11n router then this shold give better performance as I notice that the Xbox is 802.11n also.
I notice that there are plenty of routers around the £50 - £60 mark but which do not have dual band.
Is it worth going to teh expense of getting a dual band one and if so how often do you run it in 5ghz mode?
Many Thanks
Kwack
05-09-2010 10:34 AM
You probably only need a lower spec N router.
So you probably don't need a dual band router.
However if it is lagging on x-box live it may be due to your BB account at certain times of the day. Which package are you on?
EDIT: Just thought, download a network monitor to see if you're losing wireless packets, try and find out where the problem is before spending money. I did this once as bought a super fast Blekin a few years ago fo gaming but lag was worse, ran a packet tester and found out it was caused by unacceptable packet loss over the wireless - after that I ethernet-ed the gaming machine and just left wireless on everything else.
05-09-2010 11:24 PM
I am on the plusnet premium package.
The Live download speeds doesnt seem too bad to be honest - it os onyl when I try to use Media centrea as an extender that the performance is slow.
Can you recommend a netowrk trafffic monitor as I woudlnt know what I am looking at
Kwack
06-09-2010 7:10 AM
If so then you might want to look at wireless bridges with built-in 4-port ethernet swtches
e.g. http://www.amazon.co.uk/Buffalo-AirStation-Turbo-Power-WLI-TX4-G54HP/dp/B000VMUIYU/ref=sr_1_4?ie=UTF...
Using something like this gives you a wired connection between the downstairs devices, and a single wireless link to your router for internet traffic.
Make sure, before you buy, that the wireless bridge uses the same wireless encryption that you wish to use. Many of the older wireless bridges only support WEP !.
06-09-2010 12:57 PM
Just out of interest woudl a homeplug setup work with teh Xbox plugged into a hompelug and continue using WIFI for the 2nd PC. Can these things work in tandem or so you have to put your eggs in either basket?
Kwack
