Thomson TG585 v8
- Thomson TG585 v8
Thomson TG585 v8
20-02-2011 11:58 AM
hi is there somewhere i can find out how to change my channel on my router , the problem i am having is : once connected it works fine even a distance from the router but to get it to connect in the first place i have to be 3m away from the router , thank you .. ken wooffindin
Message 1 of 3
(2,319 Views)
2 REPLIES 2
Re: Thomson TG585 v8
20-02-2011 12:42 PM
With a Thomson go to 192.168.1.254 then to Home Network and click on WLAN: PlusnetWireless etc. Then go to Configure and change Channel Selection to manual and select a channel
Message 2 of 3
(378 Views)
21-02-2011 1:53 PM
HI blackbelt,
As you have a new v8 router, have you upgraded the firmware? If you're not sure, you can do this by checking the firmware version on your router is 8.2.7.8 If your router is still showing 8.2.7.7 then please perform the firmware upgrade here
Jojo
Jojo
Message 3 of 3
(378 Views)
