Temporary loss of connectivity.
- Re: Temporary loss of connectivity.
03-02-2015 3:47 PM
Quote It's basing the acceptable performance on your IP profile.
That's my point. To me this range is far from acceptable, so when I or or any other User complains about it BT (or whoever) can cite these values as being acceptable when the line is clearly capable of more.
03-02-2015 4:50 PM
Suppose the line rate is currently 1Mbit, then the acceptable speed would be based on that, i.e. 0.4 Mbps-1 Mbps. When the ip profile increases, as it will, you'll see that the acceptable throughput changes again to something more appropriate for the current rate.
03-02-2015 5:19 PM
When you said modems and filters did you mean router and filter?
I'm trying to work out what went wrong here, it sounds like you have multiple routers and or filters?
04-02-2015 7:12 AM
No I meant what I said, a quick look at my signature would tell you why. 🙂
I run two ADSL lines each connected with a DrayTek Vigor 120 ADSL+ modem, both of which are connected to a TP Link TL-R480T+ Load Balancing Router.
05-02-2015 8:13 AM
05-02-2015 8:15 AM
05-02-2015 8:35 AM
05-02-2015 9:51 AM
05-02-2015 10:12 AM
Line One:
Quote Download speedachieved during the test was - 6.78 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.83 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Line Two:
Quote Download speedachieved during the test was - 6.79 Mbps
Of course this is only relevant if the speed checker is actually smart enough to check the line associated with the phone number provided. Regardless of that I still don't have an explanation as to why my VoIP phone was dropping it's connection in the first place which is why I raised this.
I know for sure the VoIP server and its host are not to blame, implying that this was either connection (ADSL) or network issues. This happens to often for comfort, and does not look good when in the middle of a call. If I need to move to Business Accounts to get 'better' service and response then I will. But some from of explanation would be good.
05-02-2015 10:23 AM
05-02-2015 11:10 AM
I do understand that not all bugs are reproducible and as a consequence cannot be fixed, but in the context of this post I am not the only person on these fora to raise the issue of intermittent drop out. I happened to notice my drop outs because my phone's interface drew my attention to it.
However, I suspect you may well be right in the fact that I probably won't get an explanation from PN, time will tell I guess.
05-02-2015 7:32 PM
05-02-2015 8:06 PM
I've no objections to your test provided that you can give me notice. I assume this will be done tomorrow so whenever suits you an update to this thread will get an email to me.
If you're intention is to do it tonight then go ahead, regardless of any activity on the lines.
05-02-2015 8:13 PM
Quote from: plusnettony ... I've been told to check back for an update tomorrow.
I'm not in the office, but I'm sure a colleague will get this picked up for you.
06-02-2015 8:33 AM
A look at my router tells me the connections have been up for 2 days+ so I assume from that the answer is no based on the 'kick me off' comment.
Whoever is going to do this test will you either call me or give me at least 15 minutes notice, to allow my mail client time to pick up the 'Topic Reply' message please.
The VoIP connection has just been dropped and reconnected. @ 08:42
