Technicolor TG582n wireless and wired
- Re: Technicolor TG582n wireless and wired
04-02-2013 1:24 PM
Can this router be used to connect wireless devices like laptops at the same time as supporting a wired connection to a PC? The documentation from Plusnet says no but is that strictly correct?
Message 1 of 4
(872 Views)
3 REPLIES 3
04-02-2013 1:27 PM
yes it can - what documentation is that as either it is wrong or you are misreading it
Message 2 of 4
(484 Views)
04-02-2013 1:50 PM
What isn't recommended is to have a wifi & wired connection to the SAME device
Message 3 of 4
(484 Views)
04-02-2013 2:17 PM
Quote from: Hairy What isn't recommended is to have a wifi & wired connection to the SAME device
Thanks for that guys. I'm guessing that's why the manual says to use either or. They must be assuming its for 1 device.
Cheers
Message 4 of 4
(484 Views)
