Hi There,
I'm currently running software release 8.C.M.0 on the TG582n router and have just started using the built in media server.
I have noticed a number of cosmetic issues relating to the media server:
1) If I browse the Disk_a1\Media\Music directory from Windows File Explorer or a media player via Browse Folders then some directories are shown as lower case. The offending directories are ABC, U2, X&Y,GHV2 displaying as abc, u2, x&y, ghv2. I assume the problem resides with short, capitalized directory names.
2) The media server does not handle accented capitals in artist and song names when streaming the information to media players. For instance, the acute accent in Sinéad O'Connor is shown incorrectly.
3) Currently, the Music\Artist folder is built using 'Contributing Artist' tag which makes the folder just about useless (in my opinion) - especially if music collections contain lots of compilation albums. Is it possible to change the build criteria to 'Album Artist' using a CLI command?
Thanks for your help
Steve
