Technicolor TG582n FTTC actual wifi speed drops to 1Mbps
- Technicolor TG582n FTTC actual wifi speed drops to...
10-06-2014 10:24 PM
Today started to get problems with the wifi that has worked for the last few months ( not brilliant )
My printer will not connect and the laptop will connected some times
"I have turned it off and on and it is plugged in"
tryed changing most of the settings in the router still no joy jumps from 130Mbps to 1Mbps
Tried turning the wifi off with the button then back on again
any ideas ?
What 3rd part routers are available for FTTC ?
any ideas ?
Message 1 of 4
(1,279 Views)
3 REPLIES 3
Re: Technicolor TG582n FTTC actual wifi speed drops to 1Mbps
10-06-2014 10:56 PM
welcome to the forum
there are loads.. http://www.broadbandbuyer.co.uk/Shop/ShopSearch.asp?CategoryID=711&Sort=1 anything that has a WAN port and supports PPPoE should be fine.
Plenty of suggestions on this forum
Message 2 of 4
(692 Views)
11-06-2014 10:08 AM
Any router that states "cable" compatible are. Or if you want to just use the router and no BT white box you need one that has a built in VDSL modem not as common or as cheap.
Lots of people rate the TP-link ones ~ about £30 they use the BT box same as the PN one does.
Message 3 of 4
(692 Views)
12-06-2014 4:15 PM
well I still cant get any wifi to work in house.
All that used to work dont
this one ?
http://www.ebuyer.com/413595-tp-link-tl-wr843nd-300mbps-wireless-access-point-client-router-tl-wr843...
this one ?
Message 4 of 4
(692 Views)
