Technicolor TG582N firmware - DANT-1 variant
- Re: Technicolor TG582N firmware - DANT-1 variant
05-02-2013 11:57 AM
I have a Technicolor TG582N, DANT-1 variant (ex-BE).
The DANT-1 variant is used by BE, O2, Utility Warehouse.
The DANT-T variant is used by Plusnet, TalkTalk and others.
I would like to reflash my TG582N DANT-1 with Plusnet firmware so that it will work on Plusnet, but I found that the Plusnet firmware is only compatible with DANT-T variant. Does anyone have any firmware which will work on the DANT-1 ?
Message 1 of 3
(2,673 Views)
2 REPLIES 2
05-02-2013 12:04 PM
I'm sorry but this isnt possible. The difference you see in the variant is because the hardware is different. Our firmare only works on the DANT-T variant I'm afraid.
Matt
Matt
Message 2 of 3
(893 Views)
05-02-2013 2:42 PM
OK thanks Matt. Fortunately I have one of each: a DANT-T (ex-talktalk) which reflashed fine to Plusnet and I'm using it now; and a DANT-1 (ex-BEbox) which I can use as a paperweight.
Message 3 of 3
(893 Views)
