Technicolor 582n reporting 5.5Mbps wireless not 130Mbps - Slow transfers
- Technicolor 582n reporting 5.5Mbps wireless not 13...
11-06-2013 7:16 PM
My Technicolor 582n reporting 5.5Mbps wireless tonight in the web interface and file transfers from my server to laptop are unusable.
Re: Technicolor 582n reporting 5.5Mbps wireless
11-06-2013 8:20 PM
On wireless I'm only getting 1Mbps and file transfers on the LAN are under 200Kbps.
Re: Technicolor 582n reporting 5.5Mbps wireless not 130Mbps - Slow transfers
11-06-2013 9:35 PM
11-06-2013 10:21 PM
12-06-2013 9:29 AM
12-06-2013 9:42 AM
Quote from: chrish16 Only today has it started doing this. I'm using the same channel as I have been, nothing has changed. I use a wifi analyser to find the best channel to use.
May be a neighbour has changed something that has impacted your WiFi operation. Note that wifi analysers do not detect all uses of the 2.4MHz band.
