Synch speed down to 1000 Kbps why?
- Re: Synch speed down to 1000 Kbps why?
11-11-2008 1:12 AM
11-11-2008 1:59 AM
Good/bad?
11-11-2008 10:03 AM
Note to get it to work you may need to put this line in your browser first http://192.168.0.1/setup.cgi?todo=debug it only needs to be done once unless the router is rebooted
11-11-2008 2:45 PM
Although it is not under any transfer load at present (as I'm at work), member centre reports that my synch speed is now 1750 Kbps.
11-11-2008 2:46 PM
link:speed
11-11-2008 2:51 PM
Gosh I prefer Ethernet!
Figures moving in the right direction though?
Hopeing I've conquered the problem I've had with all ISPs since going always on in 2005.
11-11-2008 2:53 PM
Quote from: techguy Figures moving in the right direction though?
Yep, unless you're trying to make your connection slower.
11-11-2008 2:57 PM
Bring on fibre to the home and ethernet throughout.
Suppose I should have bought a DMT supporting router before, ah the benefit of hindsight.
Be interesting to see how it goes tonight as its patch Tuesday, grrrr.
11-11-2008 2:58 PM
11-11-2008 3:01 PM
12-11-2008 12:28 AM
Noise margin has jumped to 14 db and am getting between 350 and 550 kbps and router reports downstream of 854 Kbps, which is frankly lousy
Member centre still shows 1750 Kbps but I expect that will drop.
Do I try to lock the router to G DMT or leave on auto?
Can someone from PN please contact BT and ask them what's going on at the exchange (or rather what have they fiddled with that's recently screwed the connection)
12-11-2008 12:53 AM
12-11-2008 1:18 AM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 1920 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 750 kbps
Actual IP throughput achieved during the test was - 676 kbps
Could someone contact Bt about this please?
12-11-2008 1:36 AM
Of course life isn't fair and if your sync speed reduces the DLM responds with 75 minutes.
Sadly it's how BT implemented maxDSL.
12-11-2008 1:39 AM
I feel ridiculous moaning as its perfectly usable for browsing but it slows up downloads etc.
