Super Slow Speed
- Super Slow Speed
Super Slow Speed
26-04-2019 1:40 PM
Re: Super Slow Speed
on
26-04-2019
2:20 PM
- last edited on
04-05-2019
1:57 PM
by
Mav
I've just been looking into this, testing isn't showing any obvious issues but I can see from our connection logs that there's been some repeat disconnections.
The best thing to do next would be following the troubleshooting checks outlined here: https://www.plus.net/help/broadband/connection-troubleshooting/ if they don't help to resolve the issue you can then report a fault with us at http://faults.plus.net
Please let us know how you get on.
Moderator's note by Mike (Mav): Link fixed.
26-04-2019 3:46 PM
I'll give them a go if I can but the internet is now so bad that It won't even load up either of those links properly, just a time out error 90% of the time and unresponsive links the rest
26-04-2019 4:05 PM
Also its only affecting the Download speed, the upload speed is unchanged
280Kbps / 1.07 Mbps
8. Noise margin: | 7.2 / 38.3 |
9. Line attenuation: | 19.8 / 39.2 |
10. Signal attenuation: | 19.8 / 33.0 |
26-04-2019 4:07 PM
Hi @Robert88
Let us know how it goes please once you've done the checks.
26-04-2019 4:22 PM - edited 26-04-2019 4:23 PM
Gone through all the fault checks and nothing seems to have changed
My guess is that the line has been banded again as it's happened before, so I'll leave it connected for a couple of days now and see if that fixes it, it's just odd this happened with very few connection losses prior to this (recent connection losses have been me resetting / testing other equipment)
26-04-2019 4:49 PM
Hi @Robert88
Checking the connection from this side I can see the automated line management has banded your download speed. I have now reset the line for you to removing the banding while you are plugged in to the test socket. As you have mentioned, please let us know how it goes after a couple of days.
26-04-2019 5:38 PM
@Robert88 I have just one observation - your d/s noise margin is horrendous - something is wrong there. Until that cause is found and eliminated, you will never see a stable usable speed.
26-04-2019 6:26 PM
I don't know what you did but the speed just went up to 10Mbps within the last hour which blew past the old 6-7Mbps I usually get and is holding steady (I'm pretty sure the estimate for the area is 1-2Mbps)
Thank You
26-04-2019 6:29 PM
26-04-2019 9:52 PM
Hi there @Robert88,
@Beyhive performed a SNR reset. Essentially resetting your line and bringing the noise managing levels back to normal.
I would advise to keep an eye on the connection. Resets like this can appear to resolve the problem and sometimes they do. DLM might just need kicking into gear if there's a slight change to the signal.
However if there is a physical reason causing the noise tolerance to spike to high then the reset will only be temporary. Like putting some tape over a puncture. It might not actually 'resolve' the problem.
I would recommend seeing how it goes for the next 72 hours. If you notice your speed becomes low and your drops continue then I would recommend doing the troubleshooting checks HERE if you haven't already and then raise a fault HERE.
If you do raise a fault, please let us know on the forums and we can progress it.
26-04-2019 9:56 PM - edited 26-04-2019 9:58 PM
8. Noise margin: | 5.2 / 4.2 |
10. Signal attenuation: | 19.8 / 37.6 |
Current stats compared to 6 hours ago still fine
Thanks again
27-04-2019 7:38 AM - edited 27-04-2019 7:41 AM
@Robert88 Thanks. I wonder what was causing that massive SNR?
Agree with @Optimatts - there is probably an underlying problem somewhere.
27-04-2019 11:03 AM - edited 27-04-2019 11:05 AM
@Optimatts - welcome to the forums - a great explanation. Let’s hope that this puncture patch does not come off!
